Likes Likes:  7
Thanks Thanks:  2
Results 1 to 12 of 12
Thread: Flasher Help!
    10+ Posts Grote55's Avatar
    Aug 2019
    Federal Way, WA, USA
    Default Flasher Help!
    I went out to startup the trike for the first time this season. When I turned on the key, the flashers started flashing. The switch was not on and is not stuck. I changed the old flasher pushbutton out for a rocker-type switch last year. When I push the switch on, the hazards would "double flash" until I turned the switch off, then they would return to regular flashing. But I still can't turn them off completely.
    Does anyone have any ideas? The weather is warming up and I'd sure like to take her out without flashing the neighborhood.
    2005 GL1800 Hannigan Trike w/ Escapade trailer
    2003 GL1800a w/ ABT trailer
    1 cramped garage
    Mens Warehouse thats where i bought my Long Trench-coat...Once this virus is over the movie houses will be back in business and i can flash again.. It doesn't work for effect too well with this social distancing.........
    Oh, by the way mechanic's # 101 Go back to the last thing you worked on..IE; Rocker Switch ........
    1750+ Posts Ol' Man Jeb's Avatar
    Sep 2013
    Bettendorf, Ia
    I think Wally World sells those 9X12 full page magnifiers for these social distancing problems...
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by Grote55 View Post
    You can do that? I mean "it fits"?
    What was wrong with the old pushbutton setup? I'd bet dollars to doughnuts, that's where the problem lies.
    Aug 2019
    I pulled fuses in hopes of "resetting", but no change. I even pulled the side panel and disconnected the hazard switch, but it still flashes when the key is turned on. As I mentioned before, if I switch on the hazard switch, the lights seems to do a "double flash". Any ideas?
    1 cramped garage
    Aug 2019
    You can do that? I mean "it fits"? What was wrong with the old pushbutton setup? I'd bet dollars to doughnuts, that's where the problem lies.
    The "pushbutton" was already replace when I bought the trike. I switched it to a lighted toggle.
    I've even completely disconnected the switch, but it still flashes.
    1 cramped garage
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Is it possible it has an alarm. I've seen cars do that. You can cut the wire to the siren but the lights will still flash when it's set off.
    Aug 2019
    No Alarm. I've completely disconnected the hazard switch and the lights are still flashing.
    1 cramped garage
    Have you recently changed any bulbs? It sounds like a feedback problem. Maybe some wires are touching some where? A short in the system even from a wrong bulb could cause this kind of feedback
    Feb 2008
    Phoenix, Arizona
    Sounds like something is activating the flasher itself other than the switch. Also what was the part number of the lighted switch you found. I have been looking for one.
    JerryW n AZ
    Aug 2019
    Default Problem solved!
    I finally found the problem. I tried disconnecting everything to determine where the problem was. Someone on another forum had me tracing wires and asked to check the back of the panel for the original flasher wiring. That's when I found that behind the panel, the original flasher switch was still attached and although some of the wires were cut, the ones remaining were still live and the switch was depressed. (apparently, the spring was lost and the button didn't remain up.) Once, I disconnected that, the flashing stopped. What a relief.
    Jerry W. the flasher switch can be found anywhere on the internet. Just google "illuminated toggle switch"Name:  toggle switch.JPG
    1 cramped garage
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Glad you found it Mark, thanks for reporting how you solved it.
  1. Changed the emergency flasher and fog light switches.
    By bayoudave in forum Honda Trikes
    Last Post: 10-01-2019, 09:58 AM
  2. freewheeler and custom dynamics flasher
    By GLT in forum General Discussion
    Last Post: 04-20-2016, 09:52 AM
  3. Brake Light Flasher
    By psychogramps in forum Harley Freewheeler / Road Glide 3
    Last Post: 03-19-2016, 04:21 PM
  4. motor trike flasher unit
    By WVFoxtrotter in forum Honda Trikes
    Last Post: 10-24-2013, 01:44 PM
  5. Flasher ??
    By Rsw in forum VW Powered Trikes
    Last Post: 07-11-2012, 03:17 PM
