BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  9
Thanks Thanks:  9
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: Handlebar change out
  1. #21
    900+ Posts
    Apr 2011
    Bellville, Texas, USA
    Quote Originally Posted by kingfish108 View Post
    I am getting ready to order these bars. Did they change anything with the angle of the mirrors or affect the use of the mirrors, such as shoulder or arm blocking view? I am currently running OEM bars with OEM mirrors using the extensions.
    No, I never changed them out. After damaging the JAE connector and that problem I left the OEM bars on. Thought I would change them out later but still have never got around to it.
    Sunman
  2. #22
    50+ Posts
    Apr 2018
    Ogden, Utah, USA
    Default Handlebar change
    I had one devil of a time pulling the internal wires on a 2017 Freewheeler. The tiny molex connectors were so small I couldn’t see the barb holding the wire. I used paper clips, needles, jewelers screwdriver. Hours of frustration. Finally took the bar to Harley dealer. Old time mechanic got it loose. I got it done, had code for no connection to right hand control module. Finally found one wire wasn’t inserted enough to lock in. Fixed that. No more codes. It was quite a stressful upgrade. Krome Werks 2+2. Love ‘em.
  3. #23
    30+ Posts
    Dec 2020
    Seabrook, SC, USA
    Quote Originally Posted by 1dn5up View Post
    Alright , I’ll try ;
    First thing I did was took a picture as is , so the colors went back into the same slot.
    Move a wire in and out on the connector and you should see a small tit lock on the wire end in the connector.
    I used a small paper clip , making the end flat with a hammer turning it into a flat head screwdriver .
    Stick it in the connector between the tit and connector then pull out the wire with the end attached.
    Assemble by pushing the wire connector in ,you will hear a locking snap.
    Take note as to what side the tit end goes back into the connector.
    That step takes the longest in the bar change . Good luck .🍀👍 You can doooo it
    This is an example of straight to the point, excellent, clear, short and very descriptive response. Thank you, I could picture the procedure as I read.
  4. #24
    5+ Posts
    Dec 2020
    BIRMINGHAM
    Default Krome Werks Narrow Sweepers
    Quote Originally Posted by Moegy View Post
    Well this is 2021 - I have a 2015 Freewheeler, and want to get those bars to help me out because I am Short Armed. Do you think they will work? I don't want to pay for cable changes.
    Donna
  1. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  2. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  3. Change Out Coolant
    By FRR in forum Honda Trikes
    Last Post: 08-21-2016, 10:54 AM
  4. Handlebar Change
    By jc1300 in forum Harley Tri Glide
    Last Post: 07-04-2015, 01:32 PM
