ctdair7Jack KlarichHarley Tri GlideHot Rotors After New Pads
Speed Bleeders
Likes Likes:  38
Thanks Thanks:  1
Page 2 of 2 FirstFirst 1 2
Results 21 to 30 of 30
Thread: Amsoil
  1. #21
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by GARYD View Post
    I agree 1000%. If Amsoil is bad so is EVERY SINGLE OTHER SYN OIL BRAND. This is the biggest anti Amsoil statement I've ever seen.
    I've been using Ansoil in every single vehicle I've ever owned for the last 30 years = without one single problem.
    I sure would like to know what the big difference is on the 2020 CVO Trikes
    Typical dealer BS imo. On my 2007 CVO I had a lifter fail and grenade the 110" motor. Tech and service manager blamed it on Mobil 1 V-Twin 20w 50 oil I was using. Said they'd seen several motor problems and common denominator was the Mobil 1. BS because while I didn't know it at the time (and perhaps they did not also) early lifter and cam bearing failure was rampant on the 110" motor and to a lesser extent on the 103" motor which I know because it happened twice on my 2012 CVO with the 110" motor and I had quit using the Mobile 1 'just in case' but that didn't stop the problem.
    Fortunately I had no problem with H-D ESP honoring the warranty as this just came up as an aside while we were inspecting the damage to the motor.
    So imo forget what a dealer may say and use any oil you want as long as it meets current specs.
  2. #22
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by ultrafxr View Post
    Typical dealer BS imo. On my 2007 CVO I had a lifter fail and grenade the 110" motor. Tech and service manager blamed it on Mobil 2 V-Twin 20w 50 oil I was using. Said they'd seen several motor problems and common denominator was the Mobil 1. BS because while I didn't know it at the time (and perhaps they did not also) early lifter and cam bearing failure was rampant on the 110" motor and to a lesser extent on the 103" motor which I know because it happened twice on my 2012 CVO with the 110" motor and I had quit using the Mobile 1 'just in case' but that didn't stop the problem.
    HD knew they had a vendor problem with their lifters, still they blame non HD oil.
    Funny how HD has NEVER had any rating for their oil, while blaming others including Mobil for an inferior product. That is just non sense.
  3. #23
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Yeah I noticed that also. Auto manufacturers will say use an oil that meets a certain spec but no, no H-D does not give you that info and their oil bottles do not list what industry spec it meets . . . or does not meet, lol.
    Personally I call BS on most anything dealers tell me. And I say about my Harleys what I said years ago about computers . . . I know way more than I ever wanted to know and that is because of self defense. Seriously I just want to start it up and ride or turn my computer on and use it but unfortunately it just ain't that simple.
  4. #24
    40+ Posts
    May 2018
    forestville wisconsin usa
    Default I did a thorough Amsoil study
    https://www.oildepot.ca/does-synthet...ring-problems/
    I too have a Harley dealer whose personnel are "old school" about Amsoil meaning they do not like it at all and still refer to the "cam bearing skate" rumor. I attached the link to that article. My Amsoil study followed and I checked every Harley Dealer in Wisconsin and found out over 50% were offering Amsoil as an alternative lubricant. If it is so bad why are Harley district reps allowing their dealers to sell it? Harley dealers are independent and when dealing with several over the past 20 years I get a wide range of opinions or answers to my problems and questions. In 2010 Harley started using a new style Dunlop front tire which started chopping out prematurely. 2 dealers said it was my problem while the 3rd said it was a factory defect and covered under warranty. I wore out several compensators on a 2011 Trike and once again on a 2013 Ultra Limited. Again 2 dealers said I was shifting into 6th gear too early and also said to overfill the primary by 8-12oz. The shifting of gears is plainly spelled out in the owners manual which I followed. Overfilling the primary was the dumb answer as it now turns out and the manual specifically says "do not overfill" Harley redesigned the compensator and lubrication for 2014. The third dealer once again said the compensator is defective and replaced under warranty! CONDEMNING AMSOIL IS JUST ANOTHER EXAMPLE OF IGNORANCE ON THE PART OF A SPECIFIC DEALER.
  5. #25
    2500+ Posts GARYD's Avatar
    Oct 2011
    GLEN ELLYN, IL. USA
    The dealers down here sell Amsoil also. Should I narc on them to the mothership???
    I'm old enough to remember back in the day H-D said to never use syn oil in any Harley or you would destroy the engine.
    IBA#61162
    PATRIOT GUARD
    USMC
  6. DKCustoms postbit
  7. #26
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Hate to admit it,but, I also am old enough to remember that BS HD tried to get us to believe. I ran over 100,000 on my 03 with Amsoil & their filter. They were saying you could double the miles on changes. I did that 100k on 10k changes. Never any problems & guy I sold the bike to 8 yrs ago is still running it today. HD lies all the time ,UNTIL, they come up with a similar item.
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  8. #27
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    As far as running syn oil in the early HD Evos i used it in my 93 FXLR and it did seem to allow the gaskets to seem like they seeped around the gaskets,so switching back to dino oil they did dry up.As far as Harley dealers pushing their oil could be based on how much per quart they make.The dealer i go to sells Schaffers oil and the parts guy swears by it and their master tech runs Schaffers in his bikes.My first twin cam,2001 i ran Royal purple until they got too pricey and switched to Lucas around 2008-9 and have used it in all my Harleys without any issues.As long as it meets the specs for air cooled engine it will work fine.
  9. #28
    5+ Posts abswift's Avatar
    Oct 2019
    Texas
    Quote Originally Posted by CVOTrikeBoy View Post
    Has anyone Heard that Harley doesn't recommend Amsoil for the New 2020 CVO Trikes? My Harley Dealer was telling me that and I used it on my 2015 Trike but they say DON'T on the New 2020.
    Thanks for your Help.
    Running Amsoil in my 2020 CVO without issue. Have run it for years in my scooters...it gets really hot down here in Texas and I feel better with a full synthetic. Harley has really pushed their Syn3 BLEND for a while arguing that Harley's don't run hot enough to warrant the use of a full synthetic oil. Nope....Harley's run really cool....that's why everyone on this site is looking for ways to cool them down.
  10. #29
    50+ Posts
    Jul 2010
    silver lake kansas
    I had a 2010 triglide that I ran Amsoil in and had no issues with it. I did not purchase the extended warranty on this bike. I traded it in on a 2018 triglide and did purchase the extended warranty. When I asked my trusted service writer if using Amsoil would be a problem he said no but if I used Harley oil it would eliminate any doubts on the the warranty gods approving things if I had motor issues. Well my oil pump started to sump at 10k and the motor shot craps. The warranty gods could not blame Amsoil on for this. Just the dumb asses that built the motor. My motor should of had version 3 of the pump when it was built but somehow it had version 1. Based on the process used to evaluate what happened my service writer was right in that it eliminated any doubts about HD being responsible.
  11. #30
    1000+ Posts
    Aug 2016
    Des Moines IA US
    My 2016 had amsoil in it when I bought it used plus their filter, when it came time to change I went with harley oil and filter. When changing it I found out the amsoil filter is bigger than the harley filter, I had to go buy a 3 prong filter wrench to take off the amsoil filter. Now I don't have it and have a 2018 now and using harley oil for now, might change down the road, harley oil has served me right since 1997.
    All for now Trampas
  1. syn3 or amsoil
    By seniorsgt in forum Harley Tri Glide
    Last Post: 08-13-2019, 10:03 PM
  2. Amsoil in a GL 1500????
    By Colorado Con in forum Honda Trikes
    Last Post: 10-22-2013, 12:54 PM
  3. Amsoil 20w50 or Amsoil 60wt
    By Moneywoes in forum Harley Trike Conversions
    Last Post: 07-19-2013, 09:32 AM
