Likes Likes:  11
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: Oil Change
    Trike Talk Executive Chef
    Sully's Avatar
    Mar 2014
    Kennesaw, Ga.
    Default Oil Change
    I know what the Dealer and Handbook says, but as a Question for you. How often do you change your Oil and what do you use ?? If you have the Dealer change your oil, what do they charge ??
    Thanks, Sully
    Vietnam Vet 66 / 67
    CQ CQ DE KD4LZL
    Member Patriot Guard Riders
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I use Lucas straight 50 weight full syn in my 17 since my garage is heated and extreme cold riding for me is long gone.I change it every 5000 miles and i haven't let a dealer change my fluids in more than 30 years.
    Dec 2013
    Clarion PA USA
    Default 2,500 Miles or Winter which ever comes first.
    Mobile 1 V Twin great oil it's available most everywhere in case you need it. I have never needed to but well you know... And I do my own oil change the hardest part is cleaning up the oil on front of the motor from the filter(K&N) they have a nut on them. I have no idea what a dealer would charge. Fred
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default 4K give or take
    One hole , 8k give or take , 3 holes .
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    I change my Oil & Oil Filter every 5000 miles or once a year. I use Rotella T6, 5-40 Synthetic Oil and a Purolator Pure One PL14610 Oil Filter. Total cost is less then $30 dollars.
    Feb 2018
    Salem,va
    Amsoil if at home. Syn 3 if on the road. Change at 5 K.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I'm currently using Redline in the engine every 5,000 miles, but had great success with Lucas also, both 20W/50. As far as filters, I have used HD's 5 micron, Mobil 1 extended services & K&N, all seem fine.
    Redline Shockproof in the Tranny, as I have found nothing better, changed at 10,000 miles.
    I'm finishing up a supply of HD oil I got free in the primary, changed every 5,000 miles, then switching to Redline primary fluid.
    I change my oil most often around 3,500 miles. We have a lot of fine sand in the air here in Jacksonville Florida. I can feel it on my face I dunno about a dealership charge, I do ALL my own fluid services, and keep very good records.
    2250+ Posts
    Ocala, Florida
    ​It looks like everybody has a different opinion on how often to change their engine oil and what brand to use, Sully.
    I've used Mobil 1 15W50 (since about 1990) as it's pretty easy to find. Every oil change I send a sample into Blackstone Lab and the response I seem to always get back is: "after 5,000 miles there are enough additives left I could go another 2,000 miles". But like many Harley riders I continue to change oil at 5,000 miles. Kinda anal, ain't I.
    PC
    Beware of liberals posing as Americans.
    20+ Posts
    May 2020
    Angier NC
    Quote Originally Posted by Gideon View Post
    Gideon just answered a question I have. I’m getting ready to change the oil on my 95 GW for
    the first time. Years back when I was riding heavy of 2 wheels I was using Rotella T6 also. Now I just have to find the Purolator filter I need.
    Sep 2012
    Lakeland, FL
    After moving on from my GW trike to the 2020 Spyder RTL, I'm changing mine at 6K with Rotella T6. Book says every 9K but for me, that's too long so I'll go with my gut feeling at 9K.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I run 20-50 year round. I never waste money on synthetic.( Never heard of engine failure on a Wing anyway), change every 4500-5000 miles. Use Castrol GTX. Used it on all 9 Wings that I've owned. I ride 12-13,000 a year every year. Use Honda filters. Buy them on Amazon for big savings then from my local dealer.
  1. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  2. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  3. Leaking oil after an oil change
    By trikerider55 in forum Harley Trike Conversions
    Last Post: 06-25-2012, 08:44 AM
  4. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
  5. Stallion Oil Change
    By CAS in forum Stallion Trikes
    Last Post: 05-26-2010, 05:18 AM
