Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  1
Results 1 to 6 of 6
Thread: Replacing front wheel
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Default Replacing front wheel
    I'm going to attempt to replace my front wheel on my 2014 Triglide. I've watched about 5 YouTube videos and they all say to install the spacers with the engraved rings to the outside. I checked my wheel and noticed that the rings are on the inside. The dealer did the wheel swap last year so they installed the spacers backwards. My question is - is there a reason that the rings need to be toward the outside and if installed backwards, will that do any damage??
    IBA#61162
    PATRIOT GUARD
    USMC
    Dec 2013
    Clarion PA USA
    Don't know mine were one each way the first time I changed tires at 14,000 and change I have seen no ill effects. I did however replace them properly.
    1500+ Posts ShapeShifter's Avatar
    Aug 2018
    SW, Arkansas, USA
    Here's a snapshot from my 2016 Service Manual with a Installation Note on installing the Grooved Spacers. Oh, they don't explain why they are to be positioned with the grooves outboard.Name:  20200507_105306.jpg
    2016 Tri Glide Billet Silver w/Pinstripes ["Hi-Yo, Silver! Away!"]
    • "There is so much good in the worst of us, and so much bad in the best of us, that it ill behooves any of us to find fault with the rest of us." ..... James Truslow Adams
    • 2nd BN 33rd Armor "The Tiger Battalion" "1972 - 1974"
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    So the rings have something to do with ABS brakes.I have never owned a ABS bike so i have never payed any attention to the grooves unless they would interfere with the seals,this is before the sealed bearings.But i would always remove the spacers and leave them on what side of the bike they came out of.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    1
    Steve, I don't think that is the case at all. Non ABS bikes have the grooves on both spacers (and they are interchangeable so will work on either side). Bikes with ABS have the groves just on the right side and a different spacer on the left. The left side spacer is wired and works with the WSS (wheel speed sensor) which is needed for ABS to function. No grooves and it will only go on one way so it cannot be reversed.
    150+ Posts
    May 2016
    oberlin
    Have a police bike with abs and when dealer did first tire replacement they put the rings on the spacer the wrong way. Don’t know how long I ran until I even knew rings were on backwards according to manual. I had no abs problems or failure. I took the wheel off eventually to give the rim a good cleaning and put back together per manual.
    2016 Tri Glide and 2012 FLHTP
  1. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  2. Free wheel Front Wheel to Tri Glide
    By NC Triker in forum Harley Tri Glide
    Last Post: 10-01-2018, 06:34 PM
  3. Front Wheel--Rear Wheel
    Last Post: 08-06-2015, 12:45 PM
  4. Replacing front lowers with chrome
    By bounder04 in forum Harley Trike Conversions
    Last Post: 02-04-2011, 05:16 PM
  5. Replacing the Trunk Skin on a Stallion.
    By WildBillH in forum Stallion Trikes
    Last Post: 11-04-2010, 11:08 PM
