Likes Likes:  3
Thanks Thanks:  2
Results 1 to 9 of 9
Thread: overheating problems
    May 2020
    Hillsboro, TX USA
    Default overheating problems
    Just bought my first trike. 2019 Tri Glide. Engine light and coolant light came on. Took it back to dealer and they said it was a loose wire. Two weeks later, same thing. Now dealer is saying whoever changed plugs pinched a coolant wire. Is this possible? Would that also cause the cooling fans not to work?
    Yes and Yes Welcome aboard Doug. I'm moving this to the TRI Glide area.
    Welcome to the Gang from Western Colorado.
    As Gorilla stated ... yes, the pinched wire could cause the fans not to work, and cause the coolant to overheat.
    I am not positive, but, I believe even on the M8's, the cooling only affects the heads. The rest of the engine's air cooled and on Freewheelers the water cooling is not present. So, I don't think it's cause for panic, but, I would keep the dealer on it if things persist.
    Welcome to Trike Talk
    Anything is possible even tho the wires run thru the electrical carrier seen here, # 29 is the top cover to #28 fastened to the frame under the gas tank. The gas tank is removed to change spark plugs and wires. So bumping a wire could possibly happen. You might ask your dealer to point out to you where the wire was disturbed for your own reference
    Quote Originally Posted by Pasquali View Post
    Doug.. welcome to Trike Talk👍👍.. If it’s a wire to the fan then I guess that could be possible is Trike on the #Warranty or they want to charge you for it?
    May 2020
    Hillsboro, TX USA
    Don't know yet. He said he would let me know.Have 4 year warranty. We will see. Thanx.
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    VERY POSSIBLE, Same happened to me. 3 times back to dealer before they found it. Mine was done from changing the waterpump. Wire was down by the frame.
    150+ Posts
    May 2016
    oberlin
    Sounds like we should all be more vigilant at using the self check feature on the fans. Dual Cool models have it and I know how to check. Newer Models I do not know but assume it would be the same? Turn ignition on , dont start , roll throttle Wide Open and hold till fans run. Of course if the tempature sensor or wiring was faulty the fans would not be told to run. That's why in this case knowing what wire was pinched would be helpfull.
    2016 Tri Glide and 2012 FLHTP
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Only problem is it is an "intermittent problem" . Sometimes it is working & then it isn't.
