14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  1
Results 1 to 5 of 5
Thread: Front rotor torque
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Default Front rotor torque
    I looked all over the shop manual and TG suppliment (2014) under wheels, disks, rotors, brakes and could not find the front rotor bolt torque value anywhere.
    Does anyone know what it is? I assume you need blue Loctite?
    I tried getting that H-D yellow thread locker crap off but couldn't get it all off. Can I just put the Loctite over that stuff.
    IBA#61162
    PATRIOT GUARD
    USMC
    16-24 Foot Lbs with a dab of blue loctite
    I would clean the hub holes with a tap, if you are reusing the original rotor bolts clean the threads good of old loctite
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Harley's admonition is to get new rotor bolts and not re-use the ones you took off. More $$ for them I'm sure but perhaps it's a CYA thing about having the thread locker on the new bolts.
    Quote Originally Posted by ultrafxr View Post
    You bet HD is in CYA mode just like all others. The DOT has been up everyone's rear on using new hardware on brake and steering parts. A very good idea IMO. This is one of the reasons in the automotive field most steering and a lot of brake parts come with NEW hardware.
    250+ Posts
    Feb 2016
    Pelham AL USA
    Default Works for me.
    I have always had good results for cleaning up threads and bolts using my dremel and gun cleaning brushes. I clean the bolt threads with my variable speed dremel with the little wire wheels. For the threads inside I use a variety of brass or stainless gun cleaning brushes on a short pistol rod.
    I just run it in and out and twist slowly through the hole 2 or 3 times. I then give them a shot of air to blow the debris out and run the bolt back in. If it feels smooth and goes all the way in, all is good. If it doesn't I will use a thread chaser.
  1. Front rotor disc....
    By ODDOMAN in forum Stallion Trikes
    Last Post: 07-07-2016, 05:59 PM
  2. harley front wheel rotor question
    By butchvoss in forum Harley Trike Conversions
    Last Post: 01-21-2016, 08:23 AM
  3. polished front rotor for 2014 trike
    By scuba1954 in forum Harley Tri Glide
    Last Post: 02-06-2015, 06:41 PM
  4. Help - Can't Get Rotor Off Chrome Front Wheel.
    By Calgary in forum Honda Trikes
    Last Post: 12-06-2013, 01:22 AM
  5. warped front brake rotor---not happy with HDMC
    By pcmikey in forum Harley Tri Glide
    Last Post: 10-16-2011, 06:15 AM
