Likes Likes:  1
Results 1 to 6 of 6
Thread: brake lite
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default brake lite
    i have a 09 stallion the brake lite in dash is staying on i checked the fluid theres no leaks its not low on fluid dont have a clue why is on
    Quote Originally Posted by Just BOB View Post
    If you have a parking brake make sure it is released all the way, there is a switch attached to trip the light. If that is NOT the cause you more than likely have a master cylinder by passing pressure. If this is the problem you should see a lower and spongy pedal . This will require replacing the master cylinder
    bob jack has hit both possible issues. both have happened in the past to different stallions.
    If you have a parking brake, look to see if there is a switch wired to it. If it does un plug it is the brake light still on? If it is you have ruled out the parking brake
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Some master cylinders have float inside. If it has one make sure it's not stuck down or it will think it's low on fluid
    40+ Posts
    Mar 2019
    Myrtle Beach
    Default brake lite
    thank you for the info will check it out this week ty again
  1. TG Trunk Lite Kit
    By onahog in forum Harley Tri Glide
    Last Post: 03-22-2015, 06:51 PM
  2. Aluma-lite trailers
    By North of 49 in forum Trailers / Campers
    Last Post: 04-23-2012, 09:54 PM
  3. Lees-ure Lite Camper
    By Big Dog in forum Trailers / Campers
    Last Post: 01-16-2010, 04:07 PM
