BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  10
Thanks Thanks:  3
Results 1 to 17 of 17
Thread: 2013 Harley Tri Glide Rear Brakes
    1+ Posts
    May 2020
    Derby, Kansas USA
    Default 2013 Harley Tri Glide Rear Brakes
    Hello All, I'm new to this site so please don't be mad if I make a mistake or two. I recently purchased a Tri Glide and wasn't happy with the rear brakes so I install new rotors and pads and put in new Harley Dot 4 brake fluid after I vacuumed the old brake fluid out. I bought the speedy bleeders so it doesn't take two people to bleed the brakes. I have a hard peddle now but when I apply the brakes it barely slows me down. I did notice when I first filled the rear master brake cylinder that it took 35 pumps on the brake peddle before I had to add any fluid. I'm thinking it's the master cylinder going bad so I ordered a kit for it and it was around 20 dollars. I'm hoping it's not the calipers. Anyone have any suggestions or ever had this problem.
    Respectfully,
    JFH (Johnny)
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Johnny..........Welcome to Trike-Talk...........I'm sure someone will chime in soon with help.....Again...Welcome...
    2019 Tri-Glide.......
    Dec 2014
    Grand Junction, Co. USA
    Welcome to the Gang from Western Colorado.
    What pads and rotors did you use? OEM? If you used OEM, was there a dark coating on the rotors? My 15' had a dark coating on the rotors and the brakes stunk until that coating are off. Doubting it's a leak with the firm pedal, If I remember the 13's did not have linked brakes.
    Yesterday on one of my testing rides, a moron on a bicycle just went through an intersection. I slammed on the brakes and was pretty surprised, I left about 10 feet of rubber on the road in three lines. You could smell the rubber burning. Never tested the brakes that hard before. I was impressed, this was at about 40 mph. Trike slide to a stop straight.
    There was another stripe on the road ... single line behind the bicyclist ... Except for needing a new pair of Italian Cycle shorts ... the cyclist is fine.
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    welcome johnny like fuzzy said you might of not got the coating off. also the ebc pads are a lot better than factory. rear brakes were weak on the 13s as the were on previous years but the ebc pads make a huge difference. ive had them on my 13 for 50k. one pad change at 40k and that was about 30 k on the pads. replacements are still good
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Have a look here, this could explain part of your problem. What brand and type of pads did you use? Not all pads are created equal. Some pads are just too darn hard IMO. This will take more time to bed them in.
    Bedding in new motorcycle pads and rotors
    After 35 years as the worlds number one brand, EBC Brakes has accumulated massive experience on how to guide its customers to enjoy their brake products safely.
    Bedding in new motorcycle pads and rotors is an extremely important process – please follow these guidelines:
    Fitting New Disc Pads To Used Brake Discs/Rotors
    First of all, there are two different types of brake pad on the world markets which are sintered copper alloy or organic types. The sintered types are of course much harder and take 3-5 times longer to bed in GEOMETRICALLY to any hollow areas or ridges on a worn brake rotor. Organic pads being slightly softer bed in more quickly but also suffer from what is known as “green fade”. Green fade is explained as a heat curing of the brake material which happens over the first heavy heat cycles.
    To bed in sintered pads, drive the vehicle carefully allowing extra braking distance for the first 300 miles. Please be aware that brake performance during the bed in period may be significantly less than you have been accustomed to. What you are looking for is to see a 90%+ surface area contact between the pad and the disc or rotor before optimum braking will be achieved.
    Once your pads are 90% surface area bedded after the 300-400 miles, on a safe road, use the brakes 10 times in succession stopping your motorcycle from 60mph to 20mph to get the brakes deliberately hot. This is particularly important with the organic versions (aramid fibre types, carbon based pad types and semi-metallic pad types). After this process, the pads should settle down and normal riding and brake performance can be safely achieved.
    Fitting New Disc Pads With New Brake Discs/Rotors
    Although the brake disc/rotor surface will be perfectly flat when using a new rotor, it is still extremely important to “condition” the brake discs and match them up to your pads by driving gently for 200-300 miles. After this period, perform the heat bedding of organic pads as above in blue text.
    Always remember not to contaminate your brake pads with any fluids or greases (even brake fluid) during the install process.
    If you experience any vibration or serious loss of brake during this process, contact a professional motorcycle dealer for assistance.
  6. DKCustoms postbit
  7. #6
    1+ Posts
    Jun 2020
    Hebron, IN USA
    Default Rear Calipers 2013 HD Tri Glide
    I am new so hope i put this in the right spot. I have a 2013 HD Tri Glide and trying to find out who made the calipers for the rear I smoked one of mine the other day and would like to just rebuild it But I cant find any info. All i need is the Piston everything else on the caliper is OK. The caliper has an HB stamped on it and has two sets of numbers They are 2712-104 and 00-26456A Thank for any and all help
  8. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by lyonsbill97 View Post
    Bill welcome to Trike-Talk..........I can't help on the calipers, But i'm sure Jack Kiarich a member here who knows brakes six ways to Sunday will know....When his radar sees a post about brakes or oil he is usually on top of it...........
  9. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Is this your caliper set up # 12, HD contracted thru Lehman to build these trikes, You may have to contact them for parts
  10. #9
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Those calipers look very similar to older Mazda rear calipers. The pistons screw back in to seat inside the caliper, do NOT try to force them in very bad Ju Ju, the piston will cock in the bore and destroy itself. Rebuilding these piston actuators is tricky at best. If not done correctly they will leak for sure. Good Luck in your hunt for parts.
  11. #10
    1+ Posts
    Jun 2020
    Hebron, IN USA
    Thank You for the Welcome I sure hope someone can help I have never had so much trouble finding something out like this Its like HD took all the info and locked it up and hid the key LOL Again Thanks for the Welcome Im looking forward in reading and learning as much as i can.
  12. #11
    1+ Posts
    Jun 2020
    Hebron, IN USA
    [QUOTE=Jack Klarich;763140]Is this your caliper set up # 12, HD contracted thru Lehman to build these trikes, You may have to contact them for parts
    Thanks for the Info I do appreciate it very much I will start looking into this company Wish Me Luck LOL
  13. #12
    400+ Posts
    Feb 2020
    Washington Pa USA
    Default another brake question
    I have a 2010 tri glide ultra rear brakes work fine but pedal is low its a solid is there a adjustment?
  14. #13
    20+ Posts
    Aug 2017
    Blythewood, SC, USA
    Default 2013 Triglide rear brakes
    My 2013 Triglide rear brakes just do not stop the bike either. I think I have found that a 2016 Freewheeler rear calipers and rotors which are bigger will bolt right on. The 2013 parking brake will no longer function but I am ok with that. Anyone out there know tried this or have another replacement for the terrible rear brakes on the older Triglides?
  15. #14
    5+ Posts
    May 2017
    Bay Minette, AL, USA
    Quote Originally Posted by MGB View Post
    Yeah. I have the same question. Rear brakes on my '12 TG are marginal at best. I've looked at parts catalog and everything 'looks' like it would work from the newer TG's but I would sure like verification.
    Surely someone has tried this?
    Thanks.
    Hoggly
  16. #15
    20+ Posts
    Aug 2017
    Blythewood, SC, USA
    The calipers and rotors for a 2016 Freewheeler DO bolt right on. The park brake cable is too short but will address that at a later date. BYW, I think Hayes Performance Brakes is the caliper manufacturer. I suspect that 2014 through 2018 Triglides and Freewheeler will fit.
  17. DKCustoms postbit
  18. #16
    30+ Posts
    Sep 2021
    lake wales fl. USA
    Default rear brake's.
    Just got mine back from Harley with new brake pad's on. Yes the back brakes seem to be not so good. Have to brake new pad's in so just ride around and do some braking and they should work in. The new surface is hard and need to be used to get them broke in. Good luck.
  19. #17
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    [QUOTE=Jack Klarich;763140]Is this your caliper set up # 12, HD contracted thru Lehman to build these trikes, You may have to contact them for parts. QUOTE=]
    The OP's TG is a 2013. Harley moved the TG production in-house at the York, PA facility in 2011.
    https://www.visordown.com/news/indus...ilt-house-2011
    Parts should be (?) available through your preferred H-D stealer.
    2013 Tri Glide Ultra Classic (FLHTCUTG) DK Oil Cooler/Relocation Kit DK Custom Tank Lift Kit DK EBS Kit K&N A/C in Stock Airbox Convertible Comfort Lift Kit w/ 14" Pro Action Shocks
    Vance & Hines Monster Ovals behind OEM decatted header Motor Trike Mechanical Reverse DynaJet Power Commander V
  1. Rear Brakes on Tri-Glide
    By OlBandit in forum Harley Tri Glide
    Last Post: 08-01-2021, 12:12 PM
  2. Rear Brake Pads 2013 Tri Glide
    By JJHog in forum Harley Tri Glide
    Last Post: 07-23-2013, 07:37 AM
  3. 2013 harley tri-glide fiberglas running boards
    By sparky in forum Harley Tri Glide
    Last Post: 05-25-2013, 05:22 AM
  4. Checking out the 2013 harley tri-glide/ultra
    By Motogordo in forum Harley Trike Conversions
    Last Post: 10-30-2012, 02:50 PM
