Thanks Thanks:  1
Results 1 to 5 of 5
Thread: Front brake pad wear
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Default Front brake pad wear
    I decided to check my front brake pads on a recently purchased '03 GL1800 with a Champion solid axle kit. (I call left and right sides as I'm sitting on the bike, looking forward.) I pulled the right side and found them worn way down. The outer pad actually showing some metal and the inner pad not that far gone but still thin. I pulled the left side (side with the antidive) and found them to still be within limits. My first thought was that someone only replaced one side somewhere along the line. However, could there be a problem with the system that only one side is truly working as it should?
    On further investigation, is the antidive also called the delay valve? And, does the fact that it has a drilled out nickle in it affect this issue?
    Does the fact that the front brakes now operate from only the front lever mean that only the right side of the duel brakes are functioning?
    90+ Posts
    Sep 2012
    Magnolia, Ms USA
    Quote Originally Posted by controlu View Post
    The nickel has nothing to do with the brakes wearing. Two issues to look for. When install the wheel you have to go thru a procedure to line the wheel with the calipers. If this isn't done it will wear the brakes bad. Also there is a clip in the caliper at the top that yours shoes rides in. I have seen the clip not in correctly and this will cause wear. Also a caliper could have build up around one or more pistons not letting them retract correctly. Just a few things to look at.
    David
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    I will admit that I dont know how Champion handles brakes but on a stock GL1800, the handbrake will operate both the left and right calipers. The foot brake also operates both front brakes and the rear brakes. Some trike kits separate the front and rear brakes. I know that CSC does not but when I was changing the brake fluid last year, I was able to bleed the front brake bleeder on right caliper fine but the left caliper was plugged up somehow. I ended up after bleeding right caliper, squeezed the brake handle hard a couple times and whatever seemed to be plugging up left side came loose and I was able to finally bleed it. It could be possible that your handbrake is only operating the right caliper and something could be blocking brake line to left caliper. There is a certain procedure on which bleeders are attached to which brake. And you also need to know if the linked braking has been unlinked for the rear brake foot pedal.
    50+ Posts
    Apr 2019
    Fort Myers, FL
    Default Will test
    I believe that when I get the new pads installed I will slide a piece of paper between the left rotor and pad, squeeze the lever and see if I can pull the paper out.
    Apr 2010
    Shenandoah Valley of Virginia
    Long reach there!
    I know that 1800s have different brake integration than 1500s, where a 1500's left front is with rear brakes, only the right is on the HB MC, so often the left wears faster due to rider use.
  1. Front brake pads, uneven wear
    By controlu in forum Champion Trike
    Last Post: 05-18-2020, 11:12 AM
  2. Front brake pad retainers
    By amhc59 in forum Can Am Spyder Trikes
    Last Post: 11-30-2017, 06:20 PM
  3. Front brake pad replace
    By exphoneman in forum General Discussion
    Last Post: 08-24-2016, 09:56 AM
  4. front brake pad mileage
    By phil1945 in forum Honda Trikes
    Last Post: 12-23-2013, 07:09 PM
  5. Front Brake Pad Replacement
    By Gorilla in forum Stallion Trikes
    Last Post: 07-11-2011, 11:07 PM
