Likes Likes:  2
Results 1 to 10 of 10
Thread: Handle bar length
    Aug 2019
    Mcminnville, Oregon, USA
    Default Handle bar length
    Thinking of putting new handle bars on my 2017 triglide couple of questions.
    longest length I can put on without extending cables and wires?
    any suggestions on bars that work good?(I'm 5 10)
    THANKS
    20+ Posts
    Jan 2019
    Praradise valley,arizona,usa
    10 inch is the longest. I just had a set of Paul yaffee 10 bars put on my 2017. Perfect.
    20+ Posts
    Jan 2019
    10 inch is the longest. I just had a set of Paul yaffee 10 bars put on my 2017. Perfect. By the way I am 5. 10
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by CORVETTEJOE View Post
    THANKS
    I believe 10"possible 12" apes depending on width Harley makes pull backs but I don't know if they are higher. Khrome werks I think 12" 2+2 Narrow Sweepers from Khrome werks some people have switch to them, I could be wrong I did the 2+2 Wide Sweepers they are close to 12" and needed to change Clutch cable on my 09' they are 4" wider. Good luck on your search bars are a very personal thing what fits one doesn't the next. Travel safe Fred
Size:  162.7 KBName:  DSC00552.JPG
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Fearless View Post
    The factory bars on my Freewheeler are 12" & I really like them.
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    Suggest KromeWerks 2+2 Narrow sweepers. They work well for me and I am also 5' 10" .
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by OLBLU View Post
    The 2" higher and 2" pull back sure makes a difference on a long day's ride for sure. My smashed right wrist needed a little straighter grip the Wide one's gave me. Fred
    150+ Posts Colleydog's Avatar
    Feb 2018
    Kingsport, tn. Usa
    +1 on the khrome werks 2+2 narrow sweepers, great bars, inexpensive and easy to install yourself
    2018 115 anniversary Tri glide, 2 +2 narrow sweepers, DK comfort lift, DK tour pack relocation kit, pro action shocks, power vision, fuel moto air cleaner, s and s mufflers
    100+ Posts Longbeard71's Avatar
    Nov 2018
    Talbott tn usa
    I just installed the 2+2 narrow sweepers on mine and really like them. Mine is a 2011 all I had to change was clutch cable.
  11. #10
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    12" rise is the maximum you can go without having to change the front brake and the clutch hydraulic lines. You will need to add the short extension jumper for the handle bar switch cables but the existing throttle by wire cable will be long enough as is.
  1. Handle bar issues 2010 RSV
    By wvbiker in forum Yamaha Trikes
    Last Post: 03-17-2014, 08:09 PM
  2. Handle Bar adjustment for comfort
    By MMH in forum General Discussion
    Last Post: 02-12-2014, 10:58 PM
  3. Roadsmith Hitch Draw Bar Length
    By lgjhn in forum Honda Trikes
    Last Post: 09-29-2013, 10:13 PM
  4. Handle Bar Mount
    By Paul_Trike in forum General Discussion
    Last Post: 03-17-2012, 07:37 PM
  5. Handle bar switches
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 01-13-2012, 12:59 AM
