Phu Cat1Phu CatGeneral DiscussionIs there a TV commercial
Speed Bleeders
Likes Likes:  2
Thanks Thanks:  5
Results 1 to 17 of 17
Thread: EVO blow your issue
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default EVO blow your issue
    5 years ago HD had a EVO crate motor exchange program . The new motor came with vented heads like the twin cams . Reciently it started sucking the primary oil into the crank case creating oil overfill and puking from the motor out of every motor vent area possable.
    After checking the primary seal to motor , all was fine visibly.
    Talked to many HD techs and it is not an issue . Any one else had this problem ?
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    My shovelhead will drain down into the cases if it sits over the winter. If you're not familiar with it and add oil, you'll have an even bigger mess. Maybe a possibility for you? I'm not familiar with Evo's. They stopped building Harley's in 1970 for me.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by Sidecarbill View Post
    Nope , it’s not the sit n puke issue . Thanks any way.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Did the breather gear break.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by Mykneesbehurtin View Post
    Didn’t know it has one mainly blows oil out at 55+ mph. Gota check the book for location.
  6. #6
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by 1dn5up View Post
    #28 is an Evo Breather Hope you don't have a cracked inner primary
  7. #7
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Thanks Jack. Forgot to mention , this has been going on since it was installed.
  8. #8
    5+ Posts
    Feb 2018
    Salem,va
    Had problem one time after having cam cover off. Finally figured out I had brought wrong gasket. Missing a small vent hole as I recall. Good luck.
  9. #9
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Quote Originally Posted by Old Bear View Post
    This also could be a issue.
  10. #10
    1500+ Posts
    Apr 2016
    Dayton Ohio
    The factory gear is plastic,it has a timing mark on it.If it is out of time this can cause problems.
  11. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Some Evos seeped oil thru the stator screws, also the crank bearing inserts (LS) would work loose and allow bearing walk. This would tear up the bearing spacer and seal causing a leak, tho most times it was oil leaking into the primary. You have a tough one on your hands. Good Luck and do let us know
  12. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    The cheap plastic would also get deformed and cause scoring in the cavity it rides in. This caused major problems on lots of engines. I changed mine to an S&S steel with a modified screen for improved scavenging
  13. #13
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Still looking , so far, can’t find anything ........ the investigation continues......
  14. #14
    400+ Posts
    Feb 2015
    Sussex nj usa
    Don't know anything about Evo's. So the basics check to make sure you didn't cross an oil line. Make sure none are pinched. Some cones had different gasket configurations. Don't know if that applies to the newer bike? Harley has had so many configurations of almost the same thing, that it's easy to do something inadvertently that'll cause ya heartburn for the rest of your life.
  15. #15
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Sometimes oil will seek its own level ....Sounds simple but my 11 would blow oil out the air cleaner....I took about a half quart out and that stoped the oil from running down the engine an on my boot........
    2019 Tri-Glide.......
  16. #16
    Meme Master
    Jan 2014
    Farmington, NH USA
    One of my riding buds has the exact problem as you're having on his 91 FXR.
    He's done several crank shaft seals, even the aftermarket dual lipped type, but the problem keeps returning.
    He's resigned himself to accepting the fact that he needs to check his oil level after every longer ride.
    Another mechanic he knows told him the cases have porosity, that in turn causes this. Not sure how true this is but supposedly HD knew about it but didn't "fix" it during the Evo era.
    He's also running a non stock Andrews cam of some type. That might also have something to do with the issue, but he doesn't think that is the cause.
    I'm not sure why but my 90 FLHS has never had the issue, although it's bone stock. Amsoil maybe?
    Isn't it weird that in AMERICA, our flag and our culture offend so many people...but our benefits don't???
  17. #17
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Pull the cone cover and verify timing marks are ALL lined up. 1 tooth off on breather gear could cause a huge problem
  1. Communications 20s or 20s EVO
    By NC Triker in forum Harley Tri Glide
    Last Post: 03-03-2018, 11:00 AM
  2. WHIM and HD 20S EVO Info
    By MDF48 in forum Harley Tri Glide
    Last Post: 02-05-2018, 11:01 PM
  3. Softail evo trike build
    By JEFFCURTIS in forum Harley Trike Conversions
    Last Post: 01-05-2018, 03:06 PM
  4. 1340CC Evo trike power
    By zwerlpe in forum Harley Trike Conversions
    Last Post: 02-24-2013, 08:16 PM
  5. Blow Drying your trike?
    By Ohio Eddie in forum General Discussion
    Last Post: 04-11-2012, 12:37 PM
