Likes Likes:  1
Thanks Thanks:  5
Results 1 to 7 of 7
Thread: Stallion fuel pump
    May 2020
    Bay St Louis
    Post Stallion fuel pump
    Has anyone replaced the fuel pump on their Stallion? I need some pointers on how to do so. It started, ran for 5 seconds died and that's it. Blows the 30amp fuse for the fuel pump as soon as you turn the key. Need any and all help I can get. Thanks.
    Bama boy
    steve welcome. it should not be to bad if you can get it out. its on the left side of the tank in side mounting plate is on top. i have not tried to remove it but if it will come out though the opening you will be golden. if not then it could require tank removal which would be a big job. maybe richard the tech from tbms/motor trike can see this and advise.
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    I was wondering if you got your fuel pump replaced did it come out without any modifications what model did you replace it with
    Thank You
    Dragon
    Sep 2022
    Dallas, TX, US
    Post fuel pump location and removal
    I'm posting in case anyone is wondering about the answer to removing the fuel pump. You can expose the fuel pump by removing the rear seat back rest. You can test the electrical of the pump. However it is not removable at least on the 2009 model because the fiber glass body covers part of the pump. The only way I am aware of to remove the fuel pump is to remove the body.
    Name:  Fuel Pump arrow.jpg
    250+ Posts
    Dec 2010
    oly,wa
    I asked Richard if they had a procedure for raising the body. He said no but he sent a pdf of how to remove the fuel tank and this involves how to raise the body also.
    Dragon
    Fuel Tank Removal Procedure_split_1.pdf
    Fuel Tank Removal Procedure_split_2.pdfFuel Tank Removal Procedure_split_3.pdfFuel Tank Removal Procedure_split_4.pdf
  1. Electric fuel pump pressure
    By Doug D. in forum VW Powered Trikes
    Last Post: 04-21-2017, 08:09 PM
  2. Fuel pump help
    By Nighttrain in forum VW Powered Trikes
    Last Post: 09-06-2016, 10:29 PM
  3. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  4. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
