Likes Likes:  4
Results 1 to 6 of 6
Thread: new CSC viper owner questions
    Oct 2015
    CALDWELL
    Default new CSC viper owner questions
    About to get first 3,000 miles on new 2019 CSC Viper kit on my 2010 GL1800 Comfort. Since nearest dealer is 360 miles away, I need opinions on a few questions about first differential/rear oil change suggested for 3,000 miles....
    I see that the only preferred jacking point for the rear end of the trike is on a plate just under the differential unit..which is also the location of the main drain bolt..Not really crazy about using a jack, so
    I was wondering if I decided to use drive on ramps ... how many inches should I elevate with ramps?....Book says the normal ground clearance is 4 inches...so is another 4 inches going to be enough or maybe more ? Not a slim boy of 70+ years...needs some room and time to move on my back any more....
    Sure would appreciate Goldwinger/CSC expertise and suggestions as to the easiest and safest way to do this on my garage floor....Thanks
    Shaker
    Jun 2010
    Indianapolis, In.
    Why 3,000 miles???
    Most manufacturers recommend that the [/FONT][B]differential fluid be changed every 30,000 to 60,000 miles.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Default Ramps
    We have two identical sets of vehicle ramps that we sometimes use for our Duramax pickup.
    We use them for our Polaris General and our Honda Trike too.
    For the Trike we use 3 and align them up and then back up a few feet and drive the Trike right up the ramps and stop when to the top. That way it is leveled just like it was on the ground being all 4 ramps are identical. We use the heavy duty plastic ones and got them at NAPA on sale.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by shaker View Post
    Shaker
    I use a K&L flat motorcycle scissors jack centered from the rear of the CSC trike and use two automotive style jack stands, one under each a-arm or sometimes use my wide deck craftsman motorcycle jack with the jack stands, removing the jack to access the differential. If the ramps dont work for you that's the best option.
    250+ Posts poppajim's Avatar
    Aug 2013
    Felton DE, USA
    Why 3,000 miles???
    CSC recommends the first change at 3000 miles and then every 20,000
    Oct 2015
    CALDWELL
    Default Thanks
    Thanks for the help....I did go with the 4.5 inch plastic automotive ramps on Amazon and they worked great...had to buy 4 ramps, as they only come in pairs. I found a hinged wooden ramp example online and built mine out of 1X8 pine for changing the oil and filter on my 2010 GL1800. Constructed about same as plastic ramps then sawed in half and hinged on one side to swing out of the way to drain and replace the Honda oil filter....works great with the front ramp butted up against the curb....drive right up the ramps, do the work, and use reverse to back the trike off the ramps.
  1. new CSC viper owner questions
    By shaker in forum California Sidecar Trikes
    Owners Forum
    Last Post: 01-31-2020, 04:53 PM
  2. New CSC Viper Kit
    By gem in forum California Sidecar Trikes
    Owners Forum
    Last Post: 03-21-2018, 08:03 PM
  3. My New CSC Viper Conversion
    By pwhoever in forum California Sidecar Trikes
    Owners Forum
    Last Post: 12-13-2016, 08:12 PM
  4. CSC Unveils All New 2012 Viper GL1800
    By Trike Talk News in forum Honda Trikes
    Last Post: 11-03-2011, 02:07 PM
