LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 4 of 4
Thread: SHOCKS Question GL1800 MOTORTRIKE Solid Axle
    May 2020
    Houston
    Default SHOCKS Question GL1800 MOTORTRIKE Solid Axle
    * Shocks Question please:
    For those of you that have put a lot of miles on your GL1800 GoldWing Solid Axle MotorTrike, do you think the Original Shocks were a great ride? Or should they have been a little more heavy duty??
    I can buy the exact same shocks, but can get a little heavier spring.
    The original springs are 120/170.
    I can get the shocks with 140/200 springs... or get them with the original 120/170 springs.
    What are your thoughts about getting the 140/200 springs?
    Or should I stick with the original 120/170 springs?
    500+ Posts
    triwinggirl's Avatar
    Jun 2010
    Las vegas Nevada
    if you think the shocks were soft go ahead buy the stiffer ones.
    Jun 2015
    Evansville, In
    Quote Originally Posted by HPJ View Post
    Where do you buy new shocks?
    30+ Posts KYBubblehead's Avatar
    Aug 2017
    Covington, KY, US
    ​I actually thought they were stiff....when I wrote to Motor Trike, they said the shocks were $300 a pair!!
  1. HELP! - Need Shocks MotorTrike Solid Axle
    By HPJ in forum Honda Trikes
    Last Post: 03-30-2021, 04:16 PM
  2. Replies: 11
    Last Post: 11-19-2019, 08:40 AM
  3. new to forum bought 2008 gl1800 with solid axle champion
    By grinhart in forum New Member Introductions
    Last Post: 01-04-2018, 12:26 AM
  4. Solid Axle vs Independent Axle
    By vbbuilt in forum Harley Trike Conversions
    Last Post: 09-15-2014, 11:53 AM
