14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  25
Thanks Thanks:  8
Results 1 to 20 of 31
Thread: Screamin' Eagle 131 Fitment?
    20+ Posts
    Jun 2020
    Saint Louis, MO, USA
    Default Screamin' Eagle 131 Fitment?
    I know the MoCo says the new 131 won't fit the Trike models. I made the mistake of calling them and sitting on hold for 30 mins just to hear "this is an unsupported configuration" after they made me give them every last piece of personal info so they could mail me more stuff. Rookie mistake ..
    Hoping someone on here has had experience with the new 131 and understands the actual fitment issues. Is it a "soft" issue like voiding the warranty or EPA stuff .. or is it a major issue like the motor mounts don't match up, or there are cooling issues, drive train integration issues, etc.
    I guess the FLRT feels a lot like a regular Touring bike with a different back end to me. Hard to understand why the 131 wouldn't fit .. one dealer told me it was minor and they'd do it for me on the side .. another dealer said I should just apply the stage kits up to IV. I want the 131 if I can get it ..
    Thank you in advance.
    Mud
    Quote Originally Posted by mud32768 View Post
    Mud
    I'm gonna bet its the EPA first and foremost.......And also no warranty...
    You are going to hear horror stories of how the FLRT clutch and axle will not hold up to the 131. This is all non sense of course. The MOCO will tell you to do their stage kits instead. This too is non sense. If warranty is not an issue to you I say go for the 131, but be prepared to put a beefier clutch kit in too
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I am confused, nothing new. I looked at your profile to see the year of your Freewheeler. I thought the 2020 had lots more power than the 2015 that I own, so why would you want to spend the money for the 131? Is it one of those things that if I must ask I cannot understand?
    Quote Originally Posted by LadyonaMission View Post
    If I may answer it is a man thing bigger is always better I’ve done that many times but not always successful at times😱.. Like Tim Allen in tool Time😄..
    20+ Posts
    Jun 2020
    Exactly right .. honestly it’s more for the fun of customizing and taking off in a straight line quickly. The 114 has plenty enough go to give me white knuckles in a turn. Really appreciate all the advice, especially around the clutch and drivetrain.
    Thanks!
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Thanks!
    I can give you some suggestions to make it run a lot better without breaking the bank, and I have done most of these to my 2017. A new air cleaner will improve performance, as well as an external breather system. I saw a marked improvement in general performance by replacing the OEM spark plug wires with Thundervolt 50 wires. All of these products are available from 1 of our awesome sponsors, DK Custom Products. I also got a tank lift kit & wing deflectors from them, which helped improve cooling & the tank lift shows off that engine & makes cleaning the covers easier.
    I got a K&N air filter for the stock airbox before I knew about DK Customs air cleaners. The K&N helped alot, but their cleaners improve performance more.
    Good luck.
    100+ Posts
    May 2019
    England
    If you look at the S&S 128 kit it produces more power in both HP and torque. It’s also thousands cheaper.
    My trike is in at the moment getting an Andrews cam put in. The big bore kit is probably next in the winter.
    How much extra power does an exterior breather create. It’s a small addition but many people rate doing it.
    Quote Originally Posted by AR198 View Post
    The main reason behind the external breather is to keep the hot messy oil laden oil out of the intake. This will help the engine breath better and keep the carbon build up down
    50+ Posts
    Jul 2016
    Upper Providence Pa USA
    The reason it is stated that the 131 will not fit is the 131 kit requires a different exhaust system..... even when installing on a regular touring bike to maintain EPA compliance. I believe the cat is even bigger on the required header with the 131 kit for touring. They have not designed nor have mentioned they are going to design/manufacturer an EPA compliant exhaust for the trike set-up to accept the 131 motor and be EPA compliant will it fit, yes it will, will it covered under any warranty, no way...
    Jul 2019
    Surprise, AZ, USA
    Default 131 TRIKE
    We have done several 131 kits in the Tri-Glides and Freewheelers the customer just has to sign a waiver about warranty as we have to use an aftermarker tuner since the harley tuner will not support the 131 in a trike vin bike no fitment issues no mechanical issues to date hope this helps
    Quote Originally Posted by PGLGHDBLDR View Post
    Rick............Welcome to Trike-Talk.............
    Rick good job on the post. welcome jump in whenever you can.
    Thumbs up
    Thank you for the info and Welcome to Trike Talk
    Jan 2009
    MA,
    What year Tri glides and freewheelers have you put the 131 kits in ? have you done any 2020 ? What tuners do you use to tune them ? I have been waiting 7 weeks for FUEL MOTO to get me tune ? Today I called them again TRAVIS Talked to JAMIE WHO SAID IT IS TO COMPLICATED TO MAKE A TUNE FOR A 2020 TRI GLIDE with 128 kit ?? They took my MONEY and said no problem we can make a tune B U L L S H I T
    100+ Posts
    May 2019
    England
    Hi
    Did anyone ever get an answer on what years the 131 had been fitted too.
    I spoke to my garage today who said it was no possibility at all, and they even recommended not going past stage 2. I think HD are so careful over what goes in their engines. Is it true however it’s to much torque for the rear to handle?
    Jan 2009
    MA,
    Hi
    No he never gave a answer ? Mine ended up being 132 ftp of torque , I think the rear ends will have no problem with 140- 150 ftp of torque ? if you beat the piss out out of it doing burn out's, wheelie's and what ever ,like anything it will break, I still have not got a good tune , In the spring I have a shop called Hulten's in New York going to make a tune for it . going to do one more cam change before that , I think it will be around 140 ftp of torque ? If you want to pass a car now it has no problem , Lot's of fun to ride. But the fuel mileage Sucks .
    Jul 2019
    Surprise, AZ, USA
    Sorry for the late response they were done on 2019's and 2020's the tuners that we typically use is the TTS tuner and worked with TTS and they were able to get us a base map and our techs tune it from there hope this helps
  19. #19
    50+ Posts Ridernut's Avatar
    Lorena, Texas, USA
    Default 131
    2016 Purple Fire Harley Tri-Glide
  20. #20
    100+ Posts
    Highaltidude's Avatar
    Sep 2019
    Somerset, KY, USA
    The 131 WILL fit in a 2019 Tri Gilide.
    Chuck
  1. Replies: 19
    Last Post: 01-08-2015, 05:34 PM
  2. Screamin Eagle
    By papa cowboy in forum New Member Introductions
    Last Post: 09-05-2013, 04:44 AM
  3. New Screamin' Eagle Breather
    By Trent in forum Harley Trike Conversions
    Last Post: 11-11-2012, 09:01 PM
  4. Screamin Eagle Tuner Software
    By trikermutha in forum Harley Trike Conversions
    Last Post: 09-28-2012, 10:48 AM
  5. Screamin Eagle Tuner?
    By Cap'n Pete in forum Harley Trike Conversions
    Last Post: 06-04-2012, 08:35 AM
