Likes Likes:  5
Thanks Thanks:  2
Results 1 to 10 of 10
Thread: Speed sensor
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Default Speed sensor
    Ok my buddies 2013 Tri Glide speedo as stopped working,the odometer still works and and the 6 gear indicator doesnt work so were is the speed sensor locatated.I see the neutral switch but nothing that looks like the speed sensor.It is throwing a P0501 code VSS Sensor low.Any help would be appreciated and no he doesnt have a manual and im not buying it for him LOL Thanks
    # 21 Steve
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Right under the starter damn.Will have to pull the starter?
    Yup Too bad it is not a older Dyna model, easy to do
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Well as he left the house the speedo started working so it either had dirt on it or its going bad,so when we get back from Natural Bridge KY next weekend we will tear into it.
    Steve, the #1 cause of the sensor not working correctly is a build up of metallic filings on the magnet. If it has healed itself for now expect it to act up again. I had this problem on 2 Dynas, never on my baggers or trikes. IMO the type of gear lube used and periodic changes can make a difference. Good Luck and post up your findings
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Thanks for the info Jack,he bought it last year and has no idea what lubes were used,so that is on the agenda when we do the speed sensor.
    Steve, in the old days we would fill the case with kerosene, start the bike and run it thru the gears, Then dump the kerosene and refill the lube. WE also used Kerosene to flush the oil tanks. This worked pretty darn good
    1500+ Posts
    Apr 2016
    Dayton Ohio
    I had to do a repair on a drain plug on the oil pan and i had to make a special over sized bolt to open the threads up some and i used kerosene to flush it out,didnt even think of using it to clean the speed sensor thanks for reminding me.
  11. #10
    60+ Posts
    Mar 2010
    Western NY
    Default Wisdom
    What makes this forum so great are exchanges like these where we all get to learn something from the wise and experienced.
    '15 TG Red Sunglo/Cayenne, Chrome Forks & Wheels, LED's, TGlide Stuff Lift.
    Patriot Guard
    Previous HD's: '13 TriGlide, '13 Fat Bob, '05 Super Glide, '00 Heritage, '96 Heritage, '94 FLHTC, '77 FXR
  1. Replies: 3
    Last Post: 08-03-2014, 02:37 PM
  2. 6-Speed vs. 5-Speed Fuel Mileage
    By 1550vt in forum Honda Trikes
    Last Post: 03-08-2014, 06:36 AM
  3. Bypass the GPS Speed Sensor
    By robval87 in forum Honda Trikes
    Last Post: 02-24-2014, 08:10 AM
  4. Speed Sensor Issue
    By Lizard in forum Harley Trike Conversions
    Last Post: 09-28-2013, 02:55 AM
  5. Transmission Speed Sensor Connector location
    By Craig in forum Harley Trike Conversions
    Last Post: 03-02-2013, 11:43 AM
