Likes Likes:  2
Results 1 to 4 of 4
Thread: Clutch question
    20+ Posts gospicker's Avatar
    Jun 2014
    Azle Tx USA
    Default Clutch question
    New throw out bearing installed correctly. Hydraulic clutch adjusted correctly, but the clutch sticks in the engaged position intermittently. Anyone have any thoughts?
    150+ Posts
    Jan 2011
    Osceola Mills,PA,USA
    Hi, could there be something sticking or wrong in the master or slave cylinder? Does the pedal go down but the clutch doesn't disengage? Maybe splines worn on the trans. shaft or clutch plate?
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    If it is sticking down at the bottom of pedal stroke I would think mechanical binding of the throwout bearing or levers, if at the top of pedal travel, I would look for hydraulic return issues. make sure brake master piston is returning fully and not blocking fluid return to its reservoir....ie linkage adjustment.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    First thought is......
    are you over traveling the pressure plate?
    A diaphragm pressure plate can be pressed too far and knuckle over.
  1. V Trike Cruiser Clutch or clutch adjustment?
    By KeithK in forum Roadsmith Trikes
    Owners Forum
    Last Post: 03-25-2019, 12:23 PM
  2. Replies: 6
    Last Post: 10-31-2017, 12:55 PM
  3. Replies: 10
    Last Post: 10-10-2017, 06:53 PM
  4. Rekluse clutch vs EFM auto clutch
    By Huelshorst in forum Harley Tri Glide
    Last Post: 03-28-2016, 09:11 AM
  5. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
