Likes Likes:  5
Results 1 to 10 of 10
Thread: battery
    250+ Posts
    Dec 2010
    oly,wa
    Default battery
    Good morning
    I need to replace my battery again. just wondered if anyone has found a battery that holds up to the abuse it gets under stallion. my last 2 lasted 3 years each which is pretty good. I picked medium priced battery with 2 year warranty. does a cheaper one last just as long
    Dragon
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    I went to Pep Boys and got a Bosch AGM. I figured being over the back axle it would get bounced around quite a bit. Nothing to slosh around in them. It's been in for 2 years and still working. Rick
    Stallion #378
    Suzuki Burgman 650
    11 yrs and just but 3rd battery in last fall. napa batteries
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    well it looks like maybe 3 years for most. kinda hard to say that from 2 replies.
    Dragon
    300+ Posts
    Signal Mountain Tn
    I replaced my OEM battery in 2015, seven years on it. Installed a Walmart Everstart then and that is what I
    am still running on.
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    When you get your new battery, buy a battery tender and also think about installing jumper posts in the trunk on the left back wall so it can easily aid in a jump start for you or others as well as connecting the tender. Tomg
    250+ Posts
    Dec 2010
    oly,wa
    thanks for reply I have both in the trunk
    Dragon
    Dec 2013
    Hot Arizona, USA
    Dragon
    Me too. I got the posts with covers from Jegs. I have several of these I use on different vehicles. https://www.pulsetech.net/xc100-p-xt...esulfator.html
    Rick
    Stallion #378
    Suzuki Burgman 650
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    The battery gods have smiled on me. I purchased a duralast gold 3 year warranty. i
    I still had 3 months left on warranty. They gave me a brand new battery. now if i can only fix the rest of electric gremlins, digital display, cruise control don't work even after replacing master cylinder with new sensor, switches. oh well can't really go anywhere anyway
    Dragon
    Dec 2013
    Hot Arizona, USA
    [QUOTE=Dragon;763509]Good morning
    Check the cam on top of the cruise control unit. Mine was stuck and I couldn't get the cruise to work. I lubed it, broke it free and everything worked. I also had to replace the buttons on the steering wheel. They're not made to be out in the elements. Rick
    Stallion #378
    Suzuki Burgman 650
  1. Old Battery vs New Battery
    By Baldy_54 in forum Honda Trikes
    Last Post: 12-05-2023, 10:15 AM
  2. Battery Access Modification
    By symplysimon in forum Stallion Trikes
    Last Post: 09-02-2021, 08:26 PM
  3. Battery life and battery purchase
    By pcombe in forum Harley Trike Conversions
    Last Post: 02-21-2019, 05:53 PM
  4. When to change battery?
    By North of 49 in forum General Discussion
    Last Post: 07-04-2008, 12:18 PM
  5. Gel Battery
    By docb in forum General Discussion
    Last Post: 03-17-2008, 02:44 PM
