Results 1 to 9 of 9
Thread: after installing new shocks i suddenly have a low speed front end wobble.
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    Default after installing new shocks i suddenly have a low speed front end wobble.
    Im not at all unfamiliar with trikes especially my own since i built it myself.
    seems odd i suddenly get head shake?
    Can anyone tell me if someone makes a steering stabilizer for a 1989 Tour glide ultra- champion kit?
    It already has a raked tree and my neck bearings are set tighter than factory so those suggestions have been checked.
    just want to know about a stabilizer for this old of bike?
    Quote Originally Posted by pcombe View Post
    Paul.....Did you remove the rear wheels to put the shocks on..??..
    Feb 2013
    casper,wy. usa
    yes, they were removed
    Just a shot in the dark were the wheels
    Put back on the same side they were originally on before the wobble....Wheel weights all on where they belong...
    And were the log nuts cross tighten properly ..Ie wheels flat on the mounts not slightly cocked ....
    Feb 2013
    casper,wy. usa
    Checked that, All is right.
    Apr 2010
    Shenandoah Valley of Virginia
    If all you did was change shocks, it about has to be something like rear height change changing trail. Shocks have springs?
    Were tire pressures changed? Harder tires like with more psi can make a trike more sensitive to off side bumps, dips, etc that try to pull the trike left or right.
    Hope you get it figured out Paul ... you and that gorgeous trike have been through a lot ...
    Banned
    Jul 2016
    Felton Ca
    Perhaps the front tire is cupped from the previous worn out shocks.
    Feb 2013
    casper,wy. usa
    Quote Originally Posted by Mcahron View Post
    Not likly as i run as rear tire the exact same size as my front tir mounted backward rotation, these tires last 20.000 miles easily. abit rougher ride but not that noticeable.
    been doing it for many years with fantastic results.
  1. Replies: 10
    Last Post: 07-23-2020, 04:30 PM
  2. Front tire wear after installing a trike kit
    By Cecil K5LO in forum BMW Trikes
    Last Post: 04-21-2017, 04:56 PM
  3. Front Wheel Wobble at SLOW Speed
    By WCGeez in forum California Sidecar Trikes
    Owners Forum
    Last Post: 04-28-2015, 08:18 PM
  4. Low Speed Wobble
    By fatboy in forum Harley Trike Conversions
    Last Post: 07-17-2014, 01:28 PM
  5. Low Speed Wobble
    By Alan Oakley in forum General Discussion
    Last Post: 11-19-2010, 05:17 PM
