Likes Likes:  31
Thanks Thanks:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: Lost left wheel bearing
  1. #21
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool TBM Parking Brake
    Quote Originally Posted by Redharley View Post
    Thanks for the info.
    Bill,
    That particular parking brake is like an old Go-Kart mechanical caliper.
    As the pads wear you can adjust by relocating the lever using the stud on the back but they are notorious for making noise and locking up and not releasing.
    Lubricate the rails of the caliper and then make the final adjustment at the cable connection by the hand brake lever.
    This guy is kinda screwy but you get the idea of what you are trying to do anyhow.
    Jim Murphy
    Iron Butt Rider 2001
  2. #22
    60+ Posts
    Apr 2017
    Sunbury
    Thanks. Found right side shoe was stuck an froze in caliper. Got it apart finally cleaned it up and reassembled. Adjusted and all seems well. Will give it a good road test tomorrow before turning back over to wife. Are those pads available to purchase somewhere?
  3. #23
    Martinsburg, WV
    Cool
    Go here: mjtrikes.com
    S001304 puck
    GB1144 pads
    Jim Murphy
  4. #24
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    Jim......Con-gratulations on turning Green............
    Good job Jim.
  1. Front Wheel Bearing??
    By delta in forum Harley Tri Glide
    Last Post: 07-11-2014, 03:48 PM
  2. Voyager wheel bearing
    By sirkitrider in forum Outrigger Style Trikes
    Last Post: 03-26-2013, 06:49 AM
  3. Bad Front Wheel Bearing
    By Oldmsocko in forum Harley Trike Conversions
    Last Post: 08-29-2011, 09:24 AM
