Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  4
Thanks Thanks:  1
Results 1 to 19 of 19
Thread: Windshield question
    Jun 2020
    Meridian, ID, USA
    Default Windshield question
    I bought my first ever trike and my first Harley. I’m trying to figure out if there are windshields that will fit my 2019 FLRT. Or, is it only made for the FLRT? Can one for a Road King or FLHR fit? Thanks for the advice!
    You will get many answers yes and no on this subject. The Roadking windshield may work however the gap @ the headlight will be different. This will cause more wind buffeting than a stock FLRT shield
    300+ Posts
    Mar 2018
    Waelder, Texas
    The Road King (FLHR) windshield will “fit”, but the space around the headlight is much larger. It would probably work fine but may not look as “clean” as the Freewheeler specific shield.
    500+ Posts WindyOne's Avatar
    Dec 2009
    Va.
    Call LRS and talk to Bran. I just bought one from them. What you need to do is take measurements of the top bar holes at each end and the disance between the bottom two sets of holes that run vertical under the top bar. It took them a while but they figured out which hardware set I had. I don't think I had the hardware that was supposed to normally be on the 19 FW. Maybe yours will be better but if you measure first then talk to them you will be assured of the proper fit the first time.
    I got to take my FW out today for the first time with their windshield and I really like it over stock.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I went with the HD 20" windshield and really like it. It's a great system if you remove the shield in hot weather.
    A few manufacturers make replacement shields that use the stock hardware.
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    The FLRT is a Roadking. I replaced My Roadking windshield with an LRS. Good news: works as advertised. Bad news: poor quality. Thinner material and not as optically clear as a stock windshield. Not only that when switching over the windshield straps it cracked around the screw holes- yes I torqued it a little less then the FSM said.Whatever coating they use sucks.Its harder to keep clean than stock and streaks.I found it's necessary to use RainX for plastic.Wont buy again.
    40+ Posts
    Jul 2019
    kansas city,mo USA
    I bought a '16 freewheeler with HD windshield, it sucks, anything over 60 tried to blow my glasses off and I wear a 3/4 bell helmet. I had a street glide before so was used to a faring, very little wind. I bought a fairing from Woody's Fairings, they're made to fit freewheeler and are removable as they use the stock windshield mounts. Couldn't be happier, freeway speeds, 70 to 80, very little wind, same as my street glide. I think it looks much better also, large amount of color on tank and everything from motor back, little fender on front. Fairing brings color to the front, balancing everything out.
    40+ Posts
    Jul 2019
    kansas city,mo USA
    Default woodys faring
    40+ Posts
    Jul 2019
    kansas city,mo USA
    Not sure how that got sideways, but solved my wind problem. It comes off and on like the HD windshield. Very little wind even at 70 or 80.
    50+ Posts ole_phart's Avatar
    Oct 2019
    Smithfield, VA, USA
    Check HD's website, they make 2 specifically for the FLRT, a 16" and 20". Like MDO, I got the 20" and it's perfect during the winter. I take it off in the warmer months.
    CWO3 U.S. Army Retired
    Vietnam '69-'70, Grenada '83
    82nd, 101st, 160th SOAR
    ’01 XL1200C, ‘01 FXSTD, ‘02 FLHR, ‘03 FXDL (wife’s), '18 FXLR all sold
    2019 FLRT Freewheeler Bonneville Salt Pearl
    30+ Posts
    Jul 2018
    59 fern place
    Default windshield
    I bought the harley quick disconect windshield but its a little to short ..
    they had two choices and i bought the shorter one..
    you say i can just get a windshield replacement for it..Who makes that
    Dec 2009
    Va.
    Quote Originally Posted by Bryan View Post
    Google search turned these up as sources:
    https://www.google.com/search?q=free...hrome&ie=UTF-8
    I bought a 18" W/S and for me that height is great. Having a difficult experience with one company I can't really give you one as a recommendation.
    900+ Posts
    Bellville, Texas, USA
    Quote Originally Posted by copbiker View Post
    Hi John, what fairing is that on your Freewheeler? Did you notice any decrease in mpg or any adverse wind issues (cross wind, etc.) when you installed it? I am thinking about a fairing for my FW.
    Thanks,
    Sunman
    40+ Posts
    Jul 2019
    kansas city,mo USA
    Woody's Fairings, no loss in mpg or cross wind issues. It mounts where the stock one mounts but with a different system that's furnished with it. So less than a minute to take it off. I had two different windshields that came with the trike, both sucked, lots of wind and noise. All that went away after fairing install. They're available with or without stereo, I chose without, old school I guess. I like listening to the motor, mounted a windshield bag where the radio would live. Glad I did it, would do it again. Contact me if you need more info.
    Pic Fix
    Jan 2020
    KENNESAW
    Default Freewheeler windshield from Clearview Shields
    Bryan: I had the Harley 16 inch windshield on my 2015 Freewheeler when I got it. I experienced a lot of wind buffing with it but what I really did not like was how sensitive it made the steering when riding at interstate speeds, I thought it dangerous I had to hold on with both hands on the interstate.
    I bought a windshield from Clearview Shields, they are in Colorado. (www.clearviewshields.com) These shields use the stock mounting frame and bolts. I have 4 other Harleys and have put Clearview Shields on each of them so I have years of experience with Clearview Shields. They are polycarbonate, not lexan and are much thicker than other windshields and crystal clear. The have many heights to choose from and offer a recurve on the windshield that flips the air flow up over the helmet. My experience shows it flips bugs up and over also.
    I am 6 feet tall and have a Sundowner seat on my Freewheeler. I chose the 17 1/2 inch height and I bought their and offered only by them 2 1/2 inch wider windshield. I look over the top inch of the windshield and the recurve directs the air flow over my helmet so no buffeting. The best thing with the 2 1/2 inch wider windshield is the sensitive steering at interstate speeds is gone, the bike is now a pleasure to ride on the interstate. I've actually tested it taking my hands off the handle bars, for a few seconds, and it goes straight down the interstate.
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Received the FreedomShield the other day.Very impressed. Thicker than the LRS and wider too. Made specifically for the FLRT. The gap at the headlamp is less. It's the 19 inch which puts it at nose level for me.The recurve works just as well as the LRS but the optical quality is superior.FS recommends leaving the plastic coating on and taking it for a ride to make sure you like it. They will take it back as long as you leave the coating on it.Works very well. Disassembled and removed the the cross braces double sided tape (HD pn: 58416-77A and 58417-77) with a razor blade and replaced it with clear 1" Gorilla double sided tape.Recommed you do this no matter what brand shield you buy.Woe be unto you trying to reassemble by yourself without the stickum tape.Torqued everything down to 22 inch pounds
    using the proper sequence.Per the Touring FSM. FS has about a 4 week backorder and is more expensive than the LRS but worth the $. Rolling out before sunup theres always fog here the mountains until the sun burns it off.The LRS shield would fog so bad I would have to stop and wipe it down with a micro fiber cloth. The FS has very little fog. Both had Rain-X for plastic applied. The LRS now resides atop the burn pit pyre awaiting the Labor Day bash where I will send its demon soul back to hell where it belongs.A sacrifice to the HD gods.
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by Old Road Dog View Post
    When you can please post a picture. I did not know they used double sided tape.
  19. #19
    10+ Posts Triterrier's Avatar
    May 2020
    Bend, Oregon USA
    I have the 20” standard HD windshield. According to specs it is polycarbonate. It works fine at all speeds for me. Of course max for me so far is 75....
  1. Help, windshield cloudy gl1800 windshield
    By jnorth in forum General Discussion
    Last Post: 09-13-2019, 10:09 PM
  2. Windshield Question
    By dbruce56 in forum Honda Trikes
    Last Post: 01-04-2015, 10:10 AM
  3. Windshield vent question
    By Ozarkryder in forum Honda Trikes
    Last Post: 04-19-2012, 04:29 PM
  4. Tri-Glide Windshield height question
    By ehroyal in forum Harley Tri Glide
    Last Post: 08-06-2011, 03:37 PM
  5. Valkyrie Factory Windshield
    By rmrc51 in forum Honda Trikes
    Last Post: 02-03-2009, 11:03 AM
