14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  3
Thanks Thanks:  1
Results 1 to 16 of 16
Thread: Rear shock
    10+ Posts
    Apr 2020
    KITTANNING, Pa
    Default Rear shock
    I have a rear shock leaking oil on my Champion Trike, has anyone ever changed one, how hard is it to change?
    I took the seat off and it looks like there are 3 bolts holding the bracket on. I would like some advice before I start on the change.
    Thanks Rex
    10+ Posts
    Apr 2020
    KITTANNING, Pa
    Shocks are off, now to find new shocks that will fit. This is a SA Trike. Anyone have any suggestions? I have called several places that install trikes and they don't want to give any answers away, unless I ship the trike to them. Some places won't reply to messages left on their phones.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Rex Darla View Post
    Rex forgive my ignorance but what is an SA Trike......
    2019 Tri-Glide.......
    10+ Posts
    Apr 2020
    KITTANNING, Pa
    Sorry, solid axle, not IRS suspension.
    10+ Posts
    Apr 2020
    KITTANNING, Pa
    Found and ordered shocks, be here next Thursday.
  6. #6
    5+ Posts
    Jun 2020
    Raytown
    Default Need your advice!
    I got the same problem. Time for new shocks. Champion Solid Axle put on in 2008. Trike kit has 99,XXX miles on it. Bike has 134,XXX miles. They are progressive coil-over as far as I know. What do you have to remove to get to the top shock mounts? Please, please I hope I don't have to remove the body!! And what shocks did you put on? Thanks in advance.
  7. #7
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Quote Originally Posted by Scooter Steve View Post
    steve in 09 i was able to change the shocks from the air shocks to coil overs without removing the body but dont remember how any more mine was a 07 road king with a 09 champion kit
  8. #8
    5+ Posts
    Jun 2020
    Raytown
    Thanks. I'm going to try without taking the body off. I'm hoping there is enough room on the top mounts.
  9. #9
    10+ Posts
    Apr 2020
    KITTANNING, Pa
    Good luck Scooter, I didn't have any luck getting them off with body on.
  10. #10
    700+ Posts jjvw's Avatar
    Dec 2013
    Jenison, MI
    Do not be afraid to remove the body. You may need someone to help lift it off. You will find build instructions on the champion web site. If your bolts are in a tunnel, take the bolt and weld or lock nut, a fender washer and thin bicycle type wrench to the bolt so it can not spin around while you tighten it from below.
    Keep us posted on progress!
  11. #11
    5+ Posts
    Jun 2020
    Raytown
    I agree. I looked at the top mounts with the seat off. There is maybe 1/4" clearance. Oh, well. new adventures in store for me.
  12. #12
    5+ Posts
    Jun 2020
    Raytown
    Quote Originally Posted by jjvw View Post
    I will. Thanks for the tips.
  13. #13
    1+ Posts
    Jul 2015
    Ider
    Default Rear Shocks
    I have a 2005 vtx1800 with Champion straight axle needing shocks. May I as where you got your shock?
  14. #14
    10+ Posts
    Apr 2020
    KITTANNING, Pa
    Quote Originally Posted by Priceless View Post
  15. #15
    1+ Posts
    Jun 2021
    Roanoke Virginia USA
    Default Dave
    I just purchased the shocks from Champion. They
    Are progressive coil over shocks . They would not
    Give me a part number. They sre ,$250.00 each.
  16. #16
    250+ Posts
    Jan 2012
    oz
    $250 each for coil over spring shocks??? Unreal
  1. Tr-Glide rear shock options with shock lift mount.
    By rick1201 in forum Harley Tri Glide
    Last Post: 02-12-2016, 01:50 AM
  2. Rear Shock Lift Kit
    By Fire-Hound in forum Harley Trike Conversions
    Last Post: 01-29-2013, 05:36 PM
  3. Lehman Monarch II rear shock actuator
    By Mick in forum Lehman Trike
    Last Post: 04-21-2012, 11:47 AM
  4. C50 Suzuki rear shock needed
    By Darrell in forum Suzuki - Kawasaki Trikes
    Last Post: 03-01-2012, 02:13 PM
  5. Tri-Glide rear shock psi
    By motorman7 in forum Harley Tri Glide
    Last Post: 09-01-2009, 09:54 PM
