LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  1
Thanks Thanks:  2
Results 1 to 9 of 9
Thread: Intake problems
    Jun 2020
    Salt Lake City Utah USA
    Default Intake problems
    I have a 72 1300 vw motor I’m Having trouble putting this kit on EMPI WEBER Progressive Carburetor Kit, VW Type 3. It is hitting the oil neck/Generator support. Just seeing if anyone has had this problem before or have tips on what I could do to make this set up work for me. Thanks
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I have very very little experience with a type 3....so limited here.
    First a 72 model should be a 1600....if it is an American import model.
    Second that intake and carb set up is considered to be the worst possible choice for a type 3 or 4.
    They can and have been made to work on a type 1, by heating the intake and tuning the jetting and accel pump.
    But as for you question... the only one I can remember seeing on a type 3....the carb was not in the exact center....meaning the manifold parts were different from right to left.
    Check the tube manifolds for differences in length and offset.
    edit....
    Empi kits are not well known for how well they fit. It is not unusual to have to fix/modify the less expensive parts to get them to work.
    Jun 2020
    edit....
    Alright thanks for the advice I’ll just end up sending it back. And using what I already have.
    I have been doing Research on the engine vin number And think it is actually a type 1 the vin starts W2 AE 172 the 72 made me think it was a 1972.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    If I was the one choosing I would get dual 2 barrel weber style carbs.
    In a way they are less difficult to tune. It is more direct....do this = that result.
    But everything you do you must do 4 times.....equal to each barrel.
    If you have early original type 3 dual solex carbs then keep them.
    The type 3 fuel injection is fine on a stock engine also.
    A type 3 engine case will have the serial number stamped on the case seam next to fuel pump mount flange.
    A type 1 engine case will have the serial number stamped under the generator stand flange.
    an AE172xxxx number type 1 case would have began life as a 1970 single port.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Stock carbed type 3.
    Stock fuel injection type 3.
    type 1 carbed.
    Jun 2020
    Alright thanks! Looks like I’m working with a type 1. Does any one know any thing about the 26/27 Weber carb should i try running this or just buy the 32/36?
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I have not set a progressive up.
    But I will help you find some info.
    https://www.thesamba.com/vw/forum/vi...c.php?t=386388
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Here is the same guy but at his shops site.
    https://www.aircooled.net/making-web...led-vw-engine/
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    How about some pics of what you are working with.
    Any other mods?
    Cam?
    Heads?
    What is the actual displacement?
  1. Air Intake Plenum Break
    By Gorilla in forum Stallion Trikes
    Last Post: 09-28-2022, 10:55 PM
  2. What is the best air intake upgrade?
    By Halfnormal in forum Harley Tri Glide
    Last Post: 04-21-2020, 12:20 PM
  3. ***DK Custom - 💥BOOM💥 HD Wrinkle Black Outlaw HiFlow Intake Systems***
    By DK Custom Products in forum DK Custom Products
    Last Post: 02-05-2020, 09:44 AM
  4. Intake and Exhaust on stock trike
    By Kilratha in forum Harley Tri Glide
    Last Post: 03-04-2018, 07:39 AM
  5. GL1800 intake & exhaust
    By haddont in forum Honda Trikes
    Last Post: 06-10-2013, 01:38 AM
Tags for this Thread
