Likes Likes:  1
Results 1 to 11 of 11
Thread: Boom Box GTS
    150+ Posts
    Mar 2020
    Surprise, AZ, USA
    Default Boom Box GTS
    On my 2020 when I activate the information screen and select the engine mode it says "Engine oil OK". Is there a way to make it display the oil pressure or oil temp.
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by molokaimike View Post
    Nope. Harley has never offered an oil temp display and they took away the oil pressure reading on the 2019 model year I think it was.
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    There's no oil pressure reading on a 2017 TriGlide either.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    My 17 Triglide and now my 19 Triglide do not have a pressure gauge my 11 Triglide had a pressure gauge which would fog up in the morning so that gauge and a token would get me a ride on the subway😄 A pressure gauge is Just something else to look at and get you nervous... And probably wouldn’t get your attention till it’s too late unless it has a corresponding red idiot light😱
    2019 Tri-Glide.......
    200+ Posts rayg5102's Avatar
    Nov 2012
    New Market MD
    not to hijack this thread, but I have a 2020 and two questions on the GTS
    1. under set up, just under the language tab is one for PROJECTION on/off cant figure out what it does.
    2. under the info screen it shows length and time of ride, but I have not been able to figure how to turn this on. Is it only for routes you are tracking? is it not Active each time you ride?
    thanks. again sorry to hijack this thread
  6. DKCustoms postbit
  7. #6
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by rayg5102 View Post
    Projection is for Apple CarPlay. In order to use CarPlay projection must be ON.
    I do think the length and time of ride is only for routes you have created / loaded and activated in the gps. I've not been able to verify this but I think this information is correct.
  8. #7
    Nov 2012
    New Market MD
    Quote Originally Posted by ultrafxr View Post
    on the projection part thanks,
    on the other, what I am talking about.. It's the trip summary. have not figured out how to use it.
  9. #8
    90+ Posts
    Jun 2016
    Easley, SC
    I have a 2015 and the trip summary is accessed thru the GPS function and will reset when you turn the bike off. I would expect that the same would be true on the newer models also.
  10. #9
    300+ Posts
    evermill's Avatar
    Oct 2010
    Sierra Vista, AZ, USA
    It can be used continuous, by selecting some destination and hit the GO. If you do not stop the route then will give you the MPG, and other information. The only problem is the Navigation witch will keep telling you to turn around, I'm not a big music listener so mute the system. Just one way to work around the system.
    Does anybody else's radio reception on stink, on their 2019? Mine sure does. and yes check connections.
    2019 Tri Glide
    IBA #77718
    Retired US Army
  11. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by evermill View Post
    My 11'17' And now my 19 does....But i never use the radio away, I use an iPod and or a thumb drive ...
  12. #11
    40+ Posts Rider70's Avatar
    Jun 2019
    Gettysburg, PA, USA
    Moved my XM antenna to the top of the fairing, next to the vent. No issues other than trees here in PA.
  1. BOOM! BOX GTS: Software update error
    By quadmania in forum Harley Tri Glide
    Last Post: 02-04-2020, 12:36 AM
  2. Shuffle doesn't work on my Boom GTS 2019
    Last Post: 10-27-2019, 07:35 PM
  3. BOOM GTS Software Updates issue
    Last Post: 09-09-2019, 11:56 AM
  4. Boom box gts help
    By Wadbrown in forum Harley Tri Glide
    Last Post: 02-26-2019, 08:32 AM
  5. 2019 boom gts and iPod help
    Last Post: 02-20-2019, 12:05 PM
