14TG2TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG214TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  11
Thanks Thanks:  1
Results 1 to 20 of 22
Thread: Raking out
    20+ Posts Mek5o's Avatar
    Apr 2019
    Cheltenham
    Default Raking out
    Have 2001 Harley L1200L with Raider kit thinking of Raking it out any experts out there with advise ?
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Mek5o View Post
    all i can say is "DO IT YOU WONT REGRET IT"
    400+ Posts
    Feb 2020
    Washington Pa USA
    i used a paugcho trike kit on my 93 1200 sporty didn't rack it at first 2 yrs later i installed a 5 degree triple. it was amazing how much improvement there was do it you wont be disappointed
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Contact our President, Papa Zook (Randy) at 346-800-7946... he sells rake kits and can help you out.
    http://www.cutnshootcustoms.com
    Apr 2010
    Shenandoah Valley of Virginia
    Do it only if you are prepared to accept easier turning, less fatigue on the mountain roads, more control when accelerating while turning like exiting a gas station, and in general, a more enjoyable ride.
    Apr 2019
    Cheltenham
    Default too much?
    I was thiking of 14 degrees with 6 over tubes would that be too much?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool
    WHOA !!!!! You are going to remove just about any drive-ability and need a football field to turn around.
    Stretching it out is going to put more stress on the swingarm and make it top-heavy.
    6 degrees is maximum with 2-3" longer forks should satisfy handing and comfort.
    Do you have a Custom Sportster ?
    Jim Murphy
    Iron Butt Rider 2001
    Apr 2010
    If you are thinking of a kit that rakes just the fork tubes, 14 degrees & 6 inch over will remove all trail, be like pushing a caster backwards. I doubt you'll even locate them. Most "rake kits" you read about with trike conversions do not alter the steering stem through the frame head, they just kick the fork tubes out enough to get trail down into the 2-3" range, using 2-3" extensions to pick the front of the trike back up. The reduction in trail makes for lighter steering, but in the interest of safety & stability, you do not want to eliminate all trail.
    If talking about cutting and rewelding frame head on at 14 more degrees, I'm out.
    750+ Posts
    Jan 2010
    east windsor ct
    r you talking trees or the frame??
    either way is not going to be good on a 3 wheeler
    Apr 2019
    Cheltenham
    I was talking trees, From chopper supplies LLC
    No to cut and welding, its kit sold by chopper supply LLC.
    It's 2011 XL1200L with Raider Kit The Harley Dealer first suggested it because I was complaining of handling. He suggested 10 degrees with 6" over forks as I was shopping kits I saw these kits on Chopper supply LLC for 9,14,& 18 degree with different length forks was trying to get the best look and handling!
    750+ Posts
    Jan 2010
    east windsor ct
    the extra stress on the swing arm is not enough to worry about by any means... more on the neck than swing arm but i wouldnt worry about that either
    750+ Posts
    Jan 2010
    east windsor ct
    okay now i am sure you were not talking about changing the frame....
    i layed it out in an autocad file i dont know your bikes rake and trail
    for example i started with 30 deg rake and 5 inches of trail and 10 deg in the tree and 6 inch tube i came up with -1. inch
    if you know your rake and trail i will do it again if you like
    which is a death trap!!!!
    Sep 2016
    Springfield, Mass. USA
    My builder told me when I asked about raking:
    Out of all the rakes that I have done NO ONE has come back and said please change it back........BUT 90% have come back and say please rake this out for me...
    I have a 5.5% rake....... it works!
    750+ Posts
    Jan 2010
    east windsor ct
    some people dont get confused actually the term used is "degrees" not "%"
    Apr 2010
    You still wanting to do that?
    I saw where you said just triple trees with no frame modifications.
    Adding 14 degrees looks to me like a dangerous proposition, the 6 over tubes will level the trike, but you are gonna go from trail to lead, the front wheel will want to turn like that shopping cart when you back up.
    Lead would be when the tire contact patch is ahead of or in front of the imaginary point where that line through the steering stem intersects the roadway. You want some trail.
    750+ Posts
    Jan 2010
    east windsor ct
    the illustration is not good representation for this case as still showing trail not lead but at 14 degrees, according to my figures would be a little lead as you say but shopping cart act will play going forward not back... which is why i said it would be dangerous
    Sep 2016
    Thumbs up
    OOPS! Your correct! Thanks! (5.5 degrees) yep, that does indeed make more sense!
    Apr 2010
    the illustration is not good representation for this case as still showing trail not lead … etc …
    Well, yeah, but but it was really only meant to show in what direction one was headed with these kits. It isn't to scale, but I thought it would help illustrate … and with imagination, understand why going too far (like 14 more degrees and 6 inch over tubes) is not a good idea.
    For anyone … to clarify my shopping cart illustration, reach down and turn the casters 180 degrees so the wheel is furthest ahead in the "lead", then push the cart towards the shopping aisle and see the casters immediately try to turn back around to "trail".
  19. #19
    Apr 2019
    Cheltenham
    Thanks for the info. its been very helpful.
  20. #20
    30+ Posts alwims's Avatar
    Oct 2014
    Galmey, Missouri USA
    I'm no expert by any stretch of the imagination, but 14°? I bought my 6° rake kit from Papa Zook and it solved my hard steering perfectly. I think you are just asking for trouble installing anything over 6° on any trike. The only problem I have noticed is it takes a lot more room to make a slow speed turn, but it's liveable.
  1. Raking Trike
    By Augusta72 in forum New Member Introductions
    Last Post: 12-08-2017, 02:48 AM
  2. Question about raking a Harley
    By J.T.M. in forum General Discussion
    Last Post: 04-18-2015, 12:17 PM
  3. questions on raking
    By aussietriker in forum General Discussion
    Last Post: 04-08-2012, 07:07 PM
  4. Raking a VTX 1300?
    By Big_Steve in forum Honda Trikes
    Last Post: 05-24-2010, 01:14 PM
  5. Raking the front end
    By spiritdream in forum General Discussion
    Last Post: 10-22-2009, 03:40 PM
