Likes Likes:  6
Thanks Thanks:  4
Results 1 to 8 of 8
Thread: 2 year brake flush
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    Default 2 year brake flush
    Today i performed my 2 year brake fluid flush. Front reservoir looked pretty good, but the rear res looked like orange juice. Question: Does anyone know of a vacuum kit fitting that snugly fits the rear bleeders? The front bleeders are 3/8" and easy enough, but the rear bleeders are tiny 1/4" size. my suction fitting would not fit snugly on the rears and I had to do a pinch and turn maneuver to do the bleed. Now I'm paranoid that I might have let some air in the line. Can I replace those 1/4" rear bleeders with a 3/8" bleeder like the front?
    2018 Tri Glide Ultra Classic. Vivid Black.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I don't use a vacuum bleeder... I just have an inline check valve I put on just on the other side of the bleed valve. That takes care of the air entering the system issue.
    I must admit, do to some issues I decided to go 3 years on my Freewheeler rear brakes. I was good & did the front ones though & the dealer did the clutch during the recall, so I'm good there.
    Not having anti-lock brakes, which seemed to be the big issue, I think I'll be ok.
    Use a piece of 1/4 inch hose You can modify the end of your vacuum bleeder to use a hose like that. Otherwise if you are only gravity bleeding, as long as you keep the fluid level up in the master cylinder, the air bubbles ( if you have any air) will be pushed out the bleeder, You will not suck air back in as long as you do not run dry OR pump the brakes with a bleeder open
    Mar 2019
    Thank you, Jack. After I put the wheels back on, and after having a cold beer I started thinking more clearly and thought of just that. A clear piece of hose (like refer hose) that fits tightly onto the bleeder valve should do it. Those rear valves seem to have a very short turn to open. I will make it my obsession to cut hoses of just the right length to have a setup for each wheel so next time I tackle that job it will be an easy thing.
    So far my cost for a brake flush is about $40 including the Mighyvac bleeder and two small bottles of Dot 4. A small price to pay for the peace of mind that the Harley mech didn't screw something up.
    Name:  Bleeder 29.95 copy (2).jpeg
    Harbor Freight ... $30 ... works well.
    90+ Posts
    Apr 2019
    Crawfordville, Fl, USA
    I was flushing my brakes and hit the same snag on my 2018. Thought I would check here for a possible fix.
    And I found it. Thanks all.
    40+ Posts
    Jul 2021
    Star, Idaho Ada
    http://www.speedbleeder.com/
    I use Speed Bleeders for my brakes and clutch. I do have a Valkyrie Trike (and bike) and these work well for me.
    80+ Posts Jd1a's Avatar
    Oct 2018
    Waddell, AZ USA
    I had a dealer service my 2019, I asked to flush the brakes. They said they just check water content, then flush if necessary. Interesting change from the flush call back a few years ago. Same dealer.
  1. Rear Brake Flush/Bleed on CSC Trike
    By rhino65 in forum Honda Trikes
    Last Post: 06-08-2019, 11:20 AM
  2. Flush Mount Axle.
    By Quietrider in forum Harley Tri Glide
    Last Post: 01-02-2018, 04:01 PM
  3. cooling system flush
    By Dragon in forum Stallion Trikes
    Last Post: 04-17-2016, 05:44 PM
  4. Replies: 6
    Last Post: 09-25-2014, 10:44 AM
