SSpoon11hogmemberisoldNew Member Introduct...Hello from VA
SSpoon11ol' schoolNew Member Introduct...Hello from VA
SSpoon11Marc HNew Member Introduct...Hello from VA
SSpoon11ZammyNew Member Introduct...Hello from VA
SSpoon11Uncle FesterNew Member Introduct...Hello from VA
SSpoon11rhino 2New Member Introduct...Hello from VA
SSpoon11trike ladyNew Member Introduct...Hello from VA
SSpoon11SullyNew Member Introduct...Hello from VA
SSpoon11Jack KlarichNew Member Introduct...Hello from VA
SSpoon11GorillaNew Member Introduct...Hello from VA
SSpoon11SSpoonNew Member Introduct...Hello from VA
Likes Likes:  7
Thanks Thanks:  8
Results 1 to 15 of 15
Thread: rake and trail help
    Jun 2020
    houston,tx usa
    Unhappy rake and trail help
    I have a 2011 fxdf with 29 degree steering head. 34 degrees on the tubes with a 19 " front tire on a champion kit.
    I also have a 6 degree trip tree that I can install if needed.
    What is the best rake and trail to shoot for? The bike is great on the road but a pain in the twisties.
    Do I need longer tubes or more rake? Any ideas would be helpful. thanks dago713
    Hi Ray, Welcome to Trike Talk
    There is no real magic number for every one
    Have a look here for a calculator http://www.whosyadaddy.com/rake_trail_calculator.htm
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Hey Ray.. Welcome to TrikeTalk from the Texas Hill Country! Always happy to have another Texan on the forum. When you get it figured out the 3 Sisters will be waiting!
    750+ Posts
    Jan 2010
    east windsor ct
    put the raked trees on and the extensions u will be happy i am sure
    welcome ray
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Nice to have another Texan aboard.
    Jun 2020
    houston,tx usa
    Default rake and trail help
    Thanks for the replies.
    Jack- Thanks for the info.
    Paws, I have done all 3 sisters many times, I have had to fight the turns too much to call it fun, that is the reason I am trying to get the rake and trail right,
    stacebg- no extensions in this kit,that is the reason I am asking about longer tubes.
    I am going to do the math off of what jack posted and see what I come up with.
    thanks Dago
    Jun 2020
    houston,tx usa
    Jack , I did the math the bike has 5 degree trees and 2.03 trail. If i add 2" to the tubes {34"} I would have 2.37 trail.
    Do you think this would lighten up the front and make it better?
    Anybody have any thoughts on this?
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by dago713 View Post
    i think u will be happy and surprised how that will handle
    either one
  11. #10
    Thumbs up
    That should work pretty good
  12. #11
    Jun 2020
    houston,tx usa
    After talking with zook and hhi, I am going to install the new 6 degree trees next week with the stock length tubes.
    will let you know how it turns out. Thanks for the input.
    . Dago
  13. #12
    cool take your time its not that hard. steering head nut torque very important.
  14. #13
    Jun 2020
    houston,tx usa
    After talking with Zook and HHI I will install next week just the 6 degree trees and see if it improves the turning.
    I will let you know how it goes.
  15. #14
    750+ Posts
    Jan 2010
    east windsor ct
    this like "if you ride a bike, not a matter of IF you get rained on but a matter of WHEN"
    For the new trees it not a matter of IF it will help but a matter of HOW MUCH it will help
    you WILL be surprised i am sure
  16. #15
    Jun 2020
    houston,tx usa
    I had the new 6* trees installed to replace the 5* trees. The old trees had one fork tube crushed into a deep divit. The spring was a bitch to remove. It seems the spring would not fully expand after a bump and always had a load on it.
    The trike now has good rebound and dampening. The change in handling has improved .
    I now know the way a trike should feel when set up properly.
    The bad thing is that the original owner spent good money to install the 5* trees only to have the the guy over tighten the the lower tree bolt causing the rough ride.
    I am happy the way it turned out.
    Thanks for all the helpful ideas from everyone. Dago
  17. DKCustoms postbit
  1. Replies: 3
    Last Post: 12-25-2019, 06:22 PM
  2. Ezi Steer rake and trail
    By Terry T in forum Honda Trikes
    Last Post: 05-05-2019, 05:06 PM
  3. Rake and Trail Geometry For Motorcycles
    By Jack Klarich in forum General Discussion
    Last Post: 09-18-2017, 09:28 PM
  4. Rake, rake, rake
    By Ol' Man Jeb in forum Honda Trikes
    Last Post: 05-04-2017, 01:49 PM
  5. Rake it! Rake it! Rake it!!!!!
    By Okie in forum Honda Trikes
    Last Post: 06-07-2014, 12:18 PM
