Likes Likes:  9
Thanks Thanks:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
Thread: High Beam & Running Lights
  1. #21
    Dec 2013
    Clarion PA USA
    I like EBC pads, low on dust and sintere d copper is easier on the rotors with less noise
    J&P cycles have a good price on them thanks Jack
  2. #22
    80+ Posts Udawg's Avatar
    Jun 2020
    Kathleen, GA, USA
    Quote Originally Posted by ISP-FL View Post
    On my 16 and 19 TGs the two running lights would go out when I turned on the high beam. I know some states have restrictions on how many lights you can have on at a time in the front of a vehicle, but my high beam only certainly decreased the lighting off to the shoulder area.
    Had a front tire installed last week and when I read the paperwork there was a note from the tech indicating the fact that my running lights went out with high beams on. When I asked about this they told me it could be changed if the customer requested it.
    Needless to say I had them run it back inside and hook it up to the computer and make this change. I'm probably the last Harley owner to learn of this but I thought I would post it anyway just in case.
    Thanks to your post I had mine done this morning. Thanks again.
  1. Running boards with holes for running lights $250
    By Downtown Cowtown in forum Home Built Trikes
    Last Post: 08-13-2023, 07:11 PM
  2. Stallion High Beam
    By Greg336 in forum Stallion Trikes
    Last Post: 06-08-2019, 09:58 PM
  3. High beam and auxiliary lamps
    By ctdair in forum Harley Tri Glide
    Last Post: 06-15-2016, 07:45 PM
  4. High Beam
    By Dean H in forum Stallion Trikes
    Last Post: 09-20-2015, 07:38 PM
