Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  19
Thanks Thanks:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 23 of 23
Thread: Primary cover bolt with striped head.
  1. #21
    Dec 2013
    Clarion PA USA
    Quote Originally Posted by seniorsgt View Post
    when I worked at a shop years ago aways gave all the fasteners a wack with a hand impact first then finish taking them off with a t handle or speedhandle. Red Loctite still needs some heat.
    I have one in my special tools drawer a great tool to have amazing what it can do for you getting tight things loose 😀 Fred
  2. #22
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    The most important step in removing any bolt that has been red loctit-ed, and I have to do it way to often, is to apply heat to the bolt head. And I mean considerable heat, up close and directed to the bolt head only. Otherwise forget it coming off, it will always shear if its a small bolt. I use a small butane torch on the small bolts and it almost always works without breaking the head off.
    The trick is to keep heat on it for longer than you think its needs to be heated...like 15-30 seconds on small bolts and longer on larger bolts. The heat takes a while to soften the red loc-tite and as soon as you remove the heat it will almost immediately start to harden back up, so don't wait long before applying force to loosen the bolt, but turn it slowly with steady torque. Just remember, you are dealing with a very strong glue.
  3. #23
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Yup go to the loctite site. Right there it says heat must be used to loosen fasteners that were red loctited. The configuration of the head isn't the problem. People are unfamiliar with the amount of force it should take to loosen a bolt. So they break something. Keeping in mind that a quarter twenty fastener should probably only be torqued to maybe 7ft lbs. That ain't much.
  1. Dang Primary Torx screw head stripped
    By hardwickbv in forum Harley Tri Glide
    Last Post: 10-05-2017, 04:45 PM
  2. Primary Inspection Cover Seal
    By mirider in forum Harley Tri Glide
    Last Post: 04-09-2017, 08:02 PM
  3. Harley 4 bolt to GM 5 bolt adapter
    By TK8614 in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-08-2016, 08:35 PM
  4. Primary cover removal
    By stroker 23 in forum Harley Trike Conversions
    Last Post: 06-10-2014, 06:55 AM
  5. Tracings of vapor around head bolt
    By WalterM817 in forum Harley Trike Conversions
    Last Post: 10-04-2011, 07:17 AM
