Likes Likes:  19
Thanks Thanks:  6
Results 1 to 20 of 23
Thread: Primary cover bolt with striped head.
    10+ Posts Ocbray's Avatar
    Apr 2020
    Brooksville Fl.
    Default Primary cover bolt with striped head.
    Decided to change fluids today on my new to me 2011 trI glide. Everything is going smooth until it came time to take the primary cover off. Previous owner used red locktite. I got the first one to break free with a lot of muscle. The second one striped the T27 head. The next one broke my T27 bit. Went out and got a new bit and finally got 4 off.
    my problem is the one with the stripped head. Any thought on how to get this one out? It’s too late to go to the Harley dealer. The primary fluid is drained.
    TIA.
    Hi Ed, Welcome to Trike Talk
    I assume you are talking about the derby cover?
    If you have a dremel tool you can try grinding a screw driver slot in the bolt head. Before trying to remove it try a heat gun or even a hair dryer heat to the area, This will help loosen the loctite.
    Drilling the head of the bolt is another option. Once drilled the cover will pop off and you can use a stud remover or vise grip on the bolt. Good luck
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Hi Ed
    If you have a soldering iron, its is the best way to heat the bolt up and loosen the loctite.
    Replace them with these: https://www.albanycountyfasteners.co...p/7200-010.htm
    Scroll down the page and buy: SS 1/4-20x5/8
    You will never have the problem again!!!!
    Apr 2020
    Brooksville Fl.
    Yep derby cover. I’ll try the dermal and a BA screwdriver. Worst case is I’ll have to get a new derby cover. As long as I don’t hit the primary case cover.
    Thanks.
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    If you are careful you can use the dremel to grind the head off.
    put some tape on the cover to help keep from nicking it.
    Then buy SS Allen head screws to replace them all as suggested above.
    Bob
    Quote Originally Posted by hardwickbv View Post
    Bob
    Add some antisieze to the threads, it will help in future removal
    Quote Originally Posted by nucseal View Post
    Hi Ed
    For the life of me i never understood why Torx's were ever invented/used, Its like they were made to strip......
    Apr 2020
    Brooksville Fl.
    Ok time for an update. I’m back on the road. Used a dermal and tried the BA screwdriver. Even with a vice grip on the screwdriver it only knocked off a chunk of the head off. Drill time. Drilled the head and knocked it off. Derby cover came off. Vise grips and a little heat got the stud out.
    unfortunately I damaged the cover. Wen to the local dealer and picked one up with screws. I will be replacing them with the socket head screws suggested above.
    Thanks for everyone’s help. This is my first Harley and I don’t have much experience doing maintenance on a motorcycle. This forum is a great resource guide.
    Thanks again now it’s beer time.
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    I am so happy that you got it done.
  11. #10
    Good deal, now its time for a ride
  12. #11
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    When doing fluid changes I always loosen the screws on the derby cover before draining the fluid. Ditto on the oil filter . . . especially the first service. I've had a few oil filters that were almost welded on from the factory. On one bike I totally twisted the body of the oil filter before it finally broke loose. Don't want to leave myself in a vulnerable position with no fluid and no way to replenish. Just sayin'.
  13. #12
    Thumbs up
    Quote Originally Posted by ultrafxr View Post
    The Golden Rule
  14. #13
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    There's a few almost fit bits for torx that will cause problems. Keep in mind if your stripping a torx you probably will be rounding out an Allen. For the most part a torx will take more abuse.
  15. #14
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    At least with the socket head screw, if you strip it out (which will be hard being stainless steel), you have enough to grasp with vice grips. Glad that you got it worked out!
  16. #15
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Very easy to confuse T25 and T27. Don't ask me how I know . . . but I was a Harley newbie and I figured it out pretty quickly.
  17. DKCustoms postbit
  18. #16
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Good tip on loosening the screws first. I have found that using blue removable Loctite & torqueing to the correct spec will fix the problem.
    Except for the military, I have torqued this trike more than anything ever. So far it's working out.
    1 other tip is to use a socket on the 3 drain plugs...they will easily strip using a hexhead socket.
  19. #17
    300+ Posts
    Mar 2018
    Waelder, Texas
    I agree, Jerry. I remove the cover first to check the oil level. Then drain it.
  20. #18
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    I have used a small chisel to give the screw a good tap which will almost always break the torx bolt loose if the head is stripped out,but with red loctite preheating is mandatory.Its beyond me why anyone would use red loctite on engine covers.I dont use blue loctite on engine covers,the twin cams and M8s are pretty smooth running engines.
  21. #19
    150+ Posts
    Jul 2019
    marquette mi
    when I worked at a shop years ago aways gave all the fasteners a wack with a hand impact first then finish taking them off with a t handle or speedhandle. Red Loctite still needs some heat.
  22. #20
    150+ Posts
    May 2016
    oberlin
    Quote Originally Posted by seniorsgt View Post
    First used an impact driver like this in the 70's. Phillips head screws on dirt bike were always stripped out. I was going to suggest the same tool for this application. Friends 2 wheeler had a rear rotor Torx that broke a t-45 using a breaker bar and impact driver loosened it right up.
    2016 Tri Glide and 2012 FLHTP
  1. Dang Primary Torx screw head stripped
    By hardwickbv in forum Harley Tri Glide
    Last Post: 10-05-2017, 04:45 PM
  2. Primary Inspection Cover Seal
    By mirider in forum Harley Tri Glide
    Last Post: 04-09-2017, 08:02 PM
  3. Harley 4 bolt to GM 5 bolt adapter
    By TK8614 in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-08-2016, 08:35 PM
  4. Primary cover removal
    By stroker 23 in forum Harley Trike Conversions
    Last Post: 06-10-2014, 06:55 AM
  5. Tracings of vapor around head bolt
    By WalterM817 in forum Harley Trike Conversions
    Last Post: 10-04-2011, 07:17 AM
