Likes Likes:  2
Results 1 to 4 of 4
Thread: Foot Brake
    Jan 2020
    Seal Beach, CA. USA
    Default Foot Brake
    Hi All,
    I hope everyone is well and being safe. I have a problem, I recently broke my right ankle in two places I also have a Rinehart Air Cleaner which sticks out more than the traditional Harley Air Cleaner. In order to apply pressure to the brake I have to turn my foot inward which causes a lot of pain to my ankle.
    I clearly have no clue if there is a way to have the brake pedal extend outward instead of up. I am getting ready to take a road trip and need a fix. Any thoughts or suggestions would be most appreciated.
    Stay safe and thank you,
    Hapa B
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    http://www.dkcustomproducts.com/cata...q=Brake+pedal+
    Check this out. D K Custom Products sells quality products
    Short of maybe building a longer pedal cover ... not sure you're gonna find a pre made solution.
    I have an extended brake lever that moves the pedal forward and down a little ... removing the brake lever cover and bolting a piece of metal that is wider might be a short term fix that would work until you can find a "cleaner" solution ...
  1. Foot brake modification
    By smilinjohn in forum Yamaha Trikes
    Last Post: 03-31-2015, 11:20 PM
  2. Change foot peg / brake location?
    By smilinjohn in forum Can Am Spyder Trikes
    Last Post: 03-31-2015, 05:09 PM
  3. foot brake
    By mcridernj in forum Honda Trikes
    Last Post: 01-09-2012, 05:09 PM
  4. Foot brake
    By den52601 in forum Harley Trike Conversions
    Last Post: 03-16-2010, 03:07 PM
  5. right foot throttle (foot accelerator)
    By roadkill in forum Harley Trike Conversions
    Last Post: 10-01-2009, 09:26 PM
