Likes Likes:  6
Results 1 to 11 of 11
Thread: kruze trunk lock
    Feb 2008
    Shippensburg, Pa
    Default kruze trunk lock
    anybody else have an issue with the csc trunk lock unlatching itself.
    i can close my lower trunk and verify that it is latched. after riding awhile then stopping i walk behind the trike and the lower trunk door is unlatched.
    i have checked the cable under the seat to make sure nothing is pulling on it. i have also adjusted the pin so it has to be pushed extra to shut it and there no slop in the latching assembly. its got me puzzled.
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Quote Originally Posted by 3W-lonerider View Post
    Where is the Key Fob when you are riding?
    If it is in your pocket, you may be opening the trunk with you body movements. Just a thought.
    I know the little buttons on my Key Fob can be sensitive.
    Feb 2008
    Shippensburg, Pa
    My key and fob remains in the key switch. I also make sure the fob buttons are facing up.
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Do you have to put 2 hands on the door, one on each side of the latch and give it a good push to latch? That is the way we were shown to do it and for the latch to be set properly when we bought our Trike.
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
    Feb 2008
    Shippensburg, Pa
    I put 1 hand in the middle where the latch is. And push till i hear it click.
    Feb 2008
    Shippensburg, Pa
    seems tightening the latch so it took more pressure to close it solved the issue.
    Feb 2017
    Payson, AZ USA
    There you go, easy fix!
    Johnny 7
    Feb 2008
    Shippensburg, Pa
    Well apparently the latch wasn’t the only issue. After i adjusted it to get the latch from popping open going down the road the left side of the trunk door got all out of wack. Tried adjusting that but couldn’t get it right. So took it tp the dealer. They got it back where it’s supposed to be. They must’ve adjutant something I wasn’t. Not only that but i have no clue what came loose cause i checked all the bolts and they were all tight. But its good now.
    All well that ends well............
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Glad you got it fixed Rick!
    Aug 2020
    Waskom
    I'm having the same problem with the trunk on my Champion conversion. I adjust it and it works for a while, then it starts right back to falling open when riding. If anyone could post up a picture or two as to where the problem might be, I sure would appreciate it! Thanks!
  1. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  2. Trunk lock handle
    By adventurer 08 in forum Yamaha Trikes
    Last Post: 12-03-2013, 09:16 AM
  3. Trunk lock on Hannigan kit
    By motoadvrider in forum BMW Trikes
    Last Post: 04-24-2013, 08:04 AM
  4. TG Trunk lock
    By Bones in forum Harley Tri Glide
    Last Post: 12-06-2011, 10:13 PM
