AriNV3cycle7447Rider Safety Discuss...Maybe silly but serious question, s...
AriNV3Jack KlarichRider Safety Discuss...Maybe silly but serious question, s...
AriNV3AriNVRider Safety Discuss...Maybe silly but serious question, s...
B SMITH9rhino 2Harley Tri GlideTrailering Tri Glide
B SMITH9CasperHarley Tri GlideTrailering Tri Glide
Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
ken g9Old Road DogHarley Tri Glidereverse not working
AriNV13trike ladyNew Member Introduct...New to trike
AriNV13GorillaNew Member Introduct...New to trike
AriNV4GorillaCan Am Spyder Trike...I'm a total newbie ... Is the Spyde...
Likes Likes:  14
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 45 of 45
Thread: Pinion Seal Headache
  1. #41
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Trace View Post
    Do you mean squeeze it around the edge of the lip on the top? Or do you mean grip around the whole thing and jiggle it up? I just want to be sure l do this correctly. Because l don't want to damage that little stem under the cap right?
    Grab the whole cap and jiggle and a slight twist up should pop it off
  2. #42
    30+ Posts Trace's Avatar
    Jul 2020
    Mercersburg
    Default Pinion Seal Headache AGAIN :(
    Ok, that's what l'm going to try then. And also how much hose would you suggest, that l should attach to the vent tube?
  3. #43
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    That depends on how much room you have under your body. The higher the hose and loop the better. 1-1 1/2 foot should be enuff
  4. #44
    Jul 2020
    Mercersburg
    Alright, l'll see how much space there is under there & add the hose. Then loop it & fasten it to somewhere under the body. I read on another website where off roaders sometimes, run a vent hose in to the backside of a taillight. I guess that would work if there was already a hole there. But l wouldn't want to go making any additional holes in them. Thanks again
  5. #45
    30+ Posts Ramnight's Avatar
    Jan 2021
    Vicksburg, Michigan USA
    Has anyone thought about removing the fill plug and screwing in a barbed fitting with a hose on it, then connect it to your portable air tank with around 10 psi in it, and listen to the vent for the air to blow out. Maybe it will clear a clog that might be in it. I have been doing this for over 40 years working in maintenance shops to pressure check equipment, or look for leaks.
  1. Viper pinion seal
    By OldMnBiker in forum California Sidecar Trikes
    Owners Forum
    Last Post: 04-06-2021, 11:30 AM
  2. Pinion seal identification
    By Road Rider in forum Roadsmith Trikes
    Owners Forum
    Last Post: 02-26-2020, 09:11 AM
  3. Changed The Pinion Seal Today
    By lgjhn in forum Roadsmith Trikes
    Owners Forum
    Last Post: 02-11-2020, 07:57 AM
  4. Lehman Pinion Seal
    By durango9 in forum Lehman Trike
    Last Post: 03-21-2017, 05:43 PM
  5. Lehman straight axle pinion seal
    By dsifford in forum Lehman Trike
    Last Post: 10-04-2015, 11:02 PM
