Likes Likes:  1
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Rear Differential
    200+ Posts poppajim's Avatar
    User ID
    16065
    Aug 2013
    Newton NJ , USA
    Default Rear Differential
    Has anyone changed there own rear differential fluid?
  2. Roadsmith banner
  3. #2
    100+ Posts
    User ID
    5822
    Aug 2011
    Cumberland Md USA
    Default Rear Diff.
    Quote Originally Posted by poppajim View Post
    Mine is just about due. I did talk to a tech at a Honda/Roadsmith dealership, and he said it is very hard to get new grease in and at proper level.
    It's also easy for a tech to say that it's done but unless you watch, who knows. I guess you just have to trust them or do it yourself!
  4. #3
    60+ Posts
    User ID
    7209
    Jan 2012
    eden prairie mn
    I have no experience with a differential, But couldn't you use a syringe with a tube on it to suck the fluid out, then reverse to fill it?
  5. #4
    3000+ Posts bikerbillone's Avatar
    User ID
    9350
    Sep 2012
    Lakeland, FL
    I attempted it once, that fill plug is almost impossible to remove, and then there's the fill an almost impossible task. I finally gave it up and took it to my trike guy. Your tech guy was correct, there were two fill amounts in different diffs, and getting it to the proper fill was another problem, I'm talking the 2011/2012 year, maybe your year model has changed and the procedure is easier. Call RoadSmith and see if they can give you some tips.
  6. #5
    60+ Posts
    User ID
    7209
    Jan 2012
    eden prairie mn
    What did your trike guy do to remove the plug? Curious what he did that you can't
    Moderator
    TrikeTalk Moderator
    FuzzyWuzHe's Avatar
    User ID
    18134
    Quote Originally Posted by tourman View Post
    Tech Guys have a special way of holding their tongues ... Ask them ...
    Moses had Stage Fright, David Brought a Rock to a Sword Fight, You Picked Twelve Outsiders Nobody Would of Chosen and You Changed the World. The Moral of the Story Is: So when I Hear that devil Start Talking to Me Saying, Who Do You Think You Are? Im Just a Nobody, Trying to Tell Everybody, About Somebody that Saved My Soul. Casting Crowns
    User ID
    9350
    Sep 2012
    Lakeland, FL
    I do not know exactly, I did not get up under there to observe, and he was not forthcoming, it was a Motor Trike guy and was doing me a favor, because didn't even want to work on a RS even a diff oil change, he was aware of the remote, tight area and difficulty of getting it done. The man had lot of different wrenches which I did not have. I knew I was never gonna do it again, so I just have any interest on the 'how' of it all. One thing I know, he had a lift that would raise the machine so he could easily get up under there.
    20+ Posts
    User ID
    31161
    Jun 2020
    Gadsden, AL, USA
    Default Diff oil
    I just checked my diff oil this week. I used a 1/2in square drive ratchet. The plug was very tight. I could not move it without putting a cheater bar on it. Even then it was hard to move. Finally broke it loose and the oil was 1/2in down from the top. I screwed the plug back in, but not as tight. There is absolutely no sense in the plug being that tight.
  10. Roadsmith banner
  11. #9
    User ID
    25911
    Jan 2017
    Montoursville,PA.USA
    Default Rear Diff.
    I have changed mine twice.Just need a swivel on a ratchet to take out fill hole plug.There is a small allen scew on the bottom of diff. for a drain hole.To fill with fliud I used an outboard lower unit pump setup to fill it.
  12. #10
    20+ Posts
    User ID
    31161
    Jun 2020
    Gadsden, AL, USA
    Default How often to change
    How often should the diff gear oil need to be changed? I was thinking it is about 50k.
  1. ATV rear differential?
    By Artifex75 in forum Home Built Trikes
    Last Post: 02-16-2019, 11:34 PM
  2. Rear differential oil
    By MAMPORRERO in forum Lehman Trikes
    Owners Forum
    Last Post: 09-05-2018, 05:18 PM
  3. rear differential service
    By johndeeredr in forum Harley Tri Glide
    Last Post: 05-27-2016, 11:05 PM
  4. zerk on differential?
    By bikerbill in forum Harley Trike Conversions
    Last Post: 03-18-2011, 06:26 PM
  5. Rear Differential
    By Davidf66 in forum General Discussion
    Last Post: 02-04-2010, 03:24 PM
Bookmarks
