Likes Likes:  1
Results 1 to 14 of 14
Thread: Rear Differential
    250+ Posts poppajim's Avatar
    Aug 2013
    Felton DE, USA
    Default Rear Differential
    Has anyone changed there own rear differential fluid?
  2. Roadsmith banner
  3. #2
    100+ Posts
    Aug 2011
    Cumberland Md USA
    Default Rear Diff.
    Quote Originally Posted by poppajim View Post
    Mine is just about due. I did talk to a tech at a Honda/Roadsmith dealership, and he said it is very hard to get new grease in and at proper level.
    It's also easy for a tech to say that it's done but unless you watch, who knows. I guess you just have to trust them or do it yourself!
  4. #3
    250+ Posts
    Jan 2012
    oz
    I have no experience with a differential, But couldn't you use a syringe with a tube on it to suck the fluid out, then reverse to fill it?
  5. #4
    Sep 2012
    Lakeland, FL
    I attempted it once, that fill plug is almost impossible to remove, and then there's the fill an almost impossible task. I finally gave it up and took it to my trike guy. Your tech guy was correct, there were two fill amounts in different diffs, and getting it to the proper fill was another problem, I'm talking the 2011/2012 year, maybe your year model has changed and the procedure is easier. Call RoadSmith and see if they can give you some tips.
  6. #5
    250+ Posts
    Jan 2012
    oz
    What did your trike guy do to remove the plug? Curious what he did that you can't
    Quote Originally Posted by tourman View Post
    Tech Guys have a special way of holding their tongues ... Ask them ...
    Sep 2012
    Lakeland, FL
    I do not know exactly, I did not get up under there to observe, and he was not forthcoming, it was a Motor Trike guy and was doing me a favor, because didn't even want to work on a RS even a diff oil change, he was aware of the remote, tight area and difficulty of getting it done. The man had lot of different wrenches which I did not have. I knew I was never gonna do it again, so I just have any interest on the 'how' of it all. One thing I know, he had a lift that would raise the machine so he could easily get up under there.
    40+ Posts
    Jun 2020
    Gadsden, AL, USA
    Default Diff oil
    I just checked my diff oil this week. I used a 1/2in square drive ratchet. The plug was very tight. I could not move it without putting a cheater bar on it. Even then it was hard to move. Finally broke it loose and the oil was 1/2in down from the top. I screwed the plug back in, but not as tight. There is absolutely no sense in the plug being that tight.
  10. Roadsmith banner
  11. #9
    Jan 2017
    Montoursville,PA.USA
    Default Rear Diff.
    I have changed mine twice.Just need a swivel on a ratchet to take out fill hole plug.There is a small allen scew on the bottom of diff. for a drain hole.To fill with fliud I used an outboard lower unit pump setup to fill it.
  12. #10
    40+ Posts
    Jun 2020
    Gadsden, AL, USA
    Default How often to change
    How often should the diff gear oil need to be changed? I was thinking it is about 50k.
  13. #11
    Quote Originally Posted by MickUpi View Post
    I think 50K on gear lube would be OK, it does not live in as hostile an environment like engine oil AS long as water intrusion is not a problem you should be good to go
  14. #12
    250+ Posts
    Jan 2012
    oz
    I was told 50,000 by Road Smith when they delivered my trike
  15. #13
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    I have done mine. Having the correct socket and ratchet is a plus. If I remember correctly I used a deep socket. Go to the auto parts store and by the hand pump, I already had this pump for changing transfer case fluid on my Tahoe. If your case has gathered a lot of road crud, clean off the bottom to find a small drain plug. This plug may be flush with the case. An Allen wrench is needed to pull this out.
  16. Roadsmith banner
  17. #14
    450+ Posts Bubber's Avatar
    Jan 2020
    North Branch, Minn, USA
    tried to go to page 2 but it would not go anyway I tried to get there.
    tried 2
    tried next page
    nothing worked
    last post I could see was #10
    Bubber
    Respect Bubber
  1. zerk on differential?
    By bikerbill in forum Harley Trike Conversions
    Last Post: 04-14-2024, 06:19 PM
  2. ATV rear differential?
    By Artifex75 in forum Home Built Trikes
    Last Post: 02-16-2019, 11:34 PM
  3. Rear differential oil
    By MAMPORRERO in forum Lehman Trike
    Last Post: 09-05-2018, 05:18 PM
  4. rear differential service
    By johndeeredr in forum Harley Tri Glide
    Last Post: 05-27-2016, 11:05 PM
  5. Rear Differential
    By Davidf66 in forum General Discussion
    Last Post: 02-04-2010, 03:24 PM
