Likes Likes:  8
Thanks Thanks:  3
Results 1 to 13 of 13
Thread: Electrical/Power Problem
    80+ Posts dartref's Avatar
    Mar 2016
    Clermont, FL USA
    Default Electrical/Power Problem
    4 years, 44,000 miles. While riding, the radio gets all "staticy", then a yellow light comes on, I lose electrical power and the bike shuts down. Wait a few seconds and it restarts. It does this several times, then goes away for a while. First time it happened each time just after 90 degree turns, both left and right. They replaced a chafed wire last month saying that should be the problem, and it was fine for a month. Today it started happening again, first after a turn, then several more times going straight. Nursed it back to the dealer. We'll see. Need to get this figured out before a big Florida to Ozarks trip in a few weeks.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by dartref View Post
    I would start by insuring the battery is in good condition, that includes checking the battery cables for tightness at the terminals & the other end, especially the ground.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I am assuming you are seeing a check engine light?
    You can scan your bike for codes here https://www.fuelmotousa.com/p-29661-...ble-codes.html
    The dealer has a Digital Tech 2 scanner that we can not get, it views a lot more info on our bikes
    Mar 2016
    Clermont, FL USA
    Quote Originally Posted by MDO View Post
    Battery and connections all good
    Mar 2016
    Clermont, FL USA
    Dealer did that last time but apparently it didn't tell them what they need to know to fix the problem. They did say today that is the first thing they will check.
  6. DKCustoms postbit
  7. #6
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    I'm wondering if they did not completely fix the problem and it chaffed again.
  8. #7
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    That sure is strange if in fact the dealer used the Digital Tech scanner. It would have showed them what module was setting the code. Even the self check test you can do at home would spit out some code, very puzzling answer from a dealer for sure
  9. #8
    Mar 2016
    Clermont, FL USA
    Default Problem Found?
    Update, they called today and said they were able to duplicate the problem while on the rack. They said it's the 50amp "maxi fuse" and that they have received some bulletins on it recently. The prongs on the fuse start small and are now worn, as well as whatever it plugs into being worn. When the current fuse is jiggled, the motorcycle loses power due to the loose connection. That would make sense since when it first started was always going around a turn and accelerating causing it to shift and vibrate away from the connections. They are ordering the replacement parts, putting it back together tomorrow and taking it for a 50-60 mile test ride. Hopefully this fixes the problem and my upcoming 3000 miles round trip to the Ozarks in a few weeks can be worry-free. Thanks for all the thoughts and ideas.
  10. #9
    40+ Posts
    Jun 2020
    Gadsden, AL, USA
    Default Fuse problem
    I'm not about to say it was not the fuse, they're probably right. However it also sounds a lot like a ground problem. I would get a good quality ohm meter. Grind off the paint on the frame just above the battery negative terminal. Put one lead here from the ohm meter. Put the other lead on the battery negative terminal. If the ohm meter does not read zero you have a ground problem.
  11. #10
    4750+ Posts
    Mar 2015
    Texas
    Quote Originally Posted by MickUpi View Post
    What do you have to have the ohm meter set on? Certainly not continuity I wouldn't think. I'm totally ignorant when it comes to electricity which is causing a big problem preparing for a Ham license test.
    The only reason some people are still alive is it's illegal to shoot them.
    American Legion Rider
  12. #11
    Dec 2014
    Grand Junction, Co. USA
    Quote Originally Posted by hogcowboy View Post
    Pretty sure it would need to be set to measure resistance. And be very careful not to "accidentally" put the other lead on the + terminal ... talk about drama ... ... Tricity and I are not the best of Buds ... but ... most of the issues I have found are related to grounds.
  13. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Set your multimeter to the highest resistance range available. The resistance function is usually denoted by the unit symbol for resistance: the Greek letter omega (Ω), or sometimes by the word “ohms.” Touch the probes together to test the function, should read zero. Now you can test your circuit.
    Do not test a live circuit set with the ohms reading
  14. #13
    4750+ Posts
    Mar 2015
    Texas
    [QUOTE=Jack Klarich;772473]Set your multimeter to the highest resistance range available. The resistance function is usually denoted by the unit symbol for resistance: the Greek letter omega (Ω), or sometimes by the word “ohms.” Touch the probes together to test the function, should read zero. Now you can test your circuit.
    Do not test a live circuit set with the ohms reading[/QUOTE]
    Got it it. Thanks. Me and electricity do not see eye to eye so I generally stay as far away as possible. But trying to study for a Ham license is filling my head full of electrical JUNK. So I might try applying some of new found info at some point. Sparks usually fly when I'm around the stuff so thanks for that last warning.
  1. No Electrical Power
    By 2006gold in forum Stallion Trikes
    Last Post: 10-30-2017, 10:01 AM
  2. Power...Power, I need more power
    By SJR in forum Harley Trike Conversions
    Last Post: 08-14-2011, 10:37 AM
  3. I have an electrical problem! Help!
    By Boscoporp in forum General Discussion
    Last Post: 04-01-2010, 03:57 PM
  4. electrical problem, volt meter in 12v range
    By silverdevil in forum Stallion Trikes
    Last Post: 03-12-2010, 11:50 PM
  5. Electrical Problem - Blowing Fuse
    By patriot in forum Honda Trikes
    Last Post: 10-15-2009, 08:50 AM
