Likes Likes:  12
Thanks Thanks:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: Front Wheel Bearing Failure
  1. #21
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    2 part answer, if Maxwell is like me he probably popped the seals off and repacked the bearings with some better grease ( the grease in most of these bearings is pretty weak looking IMO)
    As far as replacing the front bearings @ tire time, probably will as long as the wheel is off, I do not like surprises
    Before repacking new wheel bearings, do you clean out the original grease for just palm in the new grease until it's thoroughly in the bearings?
  2. #22
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    After repacking do you use new seals?
  3. #23
    Quote Originally Posted by OLBLU View Post
    Thank you all for the replies.
    Will the Timken 205PP also fit the rears?
    No, it is a different bearing. I have not had one apart yet but Kevin @ D K Customs has I bet he has a number
  4. #24
    Quote Originally Posted by Philip R View Post
    [SP]
    Yes i clean out the old grease and check the inner races, I rinse the bearings in hot soapy water and blow dry before packing. If you are careful in removing the seals they can be reused again, look closely at the sealing lips for tears or irregularity's
  5. #25
    250+ Posts
    Nov 2012
    Bradenton, FL.
    My 2017 Tri lost front bearings at 3600 miles
    2019 Red and Silver Tri Glide
  7. #26
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    My 2017 front wheel bearings lasted 14,000 miles,shameful that wheel bearings in my truck have 140,000 miles on them.
  1. Freewheeler front wheel bearings failure
    By stratcpo in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-06-2017, 06:47 PM
  2. front wheel bearing honda vt750ca with motortrike roadhawk rims
    By leatherandflames in forum Honda Trikes
    Last Post: 01-16-2015, 10:39 PM
  3. front wheel bearing honda vt750ca with motortrike roadhawk rims
    Last Post: 01-13-2015, 11:16 AM
  4. Front Wheel Bearing??
    By delta in forum Harley Tri Glide
    Last Post: 07-11-2014, 03:48 PM
  5. Bad Front Wheel Bearing
    By Oldmsocko in forum Harley Trike Conversions
    Last Post: 08-29-2011, 09:24 AM
