Battery is charged; power on, will not crank.
Hi Jennifer Welcome to Trike Talk
Do you have a good battery in your Fob?
Check the P and A fuse in the fuse box under the left side cover
make sure the run switch on handle bars in on
Is your trike in neutral, What happens if you hold the brake on with the clutch pulled in?
Have you load tested your battery?
Follow this link and scan your trikes ECM for codes, if you do have a no start you may get a communication code
https://www.fuelmotousa.com/p-29661-harley-trouble-codes.html
  • Like
Reactions: MDO
I notice far too many are hit and runs. With a 2020 model my first go-to would be the dealer. There are such things as bad batteries right from the get-go. And dealerships replace those bad batteries all the time. Hope she isn't too embarrassed to let us know the outcome.
Probably.....Had the kill switch in the off position...;)....
ve7poi
ve7poi
