Likes Likes:  12
Thanks Thanks:  1
Results 1 to 16 of 16
Thread: Battery is charged; power on, will not crank.
    Aug 2020
    Carrollton, GA
    Default Battery is charged; power on, will not crank.
    Does not even turn over
    Hi Jennifer Welcome to Trike Talk
    Do you have a good battery in your Fob?
    Check the P and A fuse in the fuse box under the left side cover
    make sure the run switch on handle bars in on
    Is your trike in neutral, What happens if you hold the brake on with the clutch pulled in?
    Have you load tested your battery?
    Follow this link and scan your trikes ECM for codes, if you do have a no start you may get a communication code
    https://www.fuelmotousa.com/p-29661-...ble-codes.html
    Jennifer.......Welcome to Trike-Talk......
    Have you tried starting with both FOB's...?
    Look at your speedometer, is the red security light flashing when you are sitting on the trike?
    Welcome to the Gang from Western Colorado.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Quote Originally Posted by MsE View Post
    Welcome Jennifer. Your profile says you have a 2020 FW. Don't mess with it. Call the dealer & have them pick it up for analysis. You have a factory 2 year warranty, including the battery. For 2 years it's their problem.
    Give them a call!
    welcome jennifer
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    . Hope your problem is solved. Ride safe.
    Do you have any new info on your no start issue?
    Hope she's not a one and done poster..........Green light is indicating she's on line...
    I hope she gets the help she needs. Her profile shows a 2020 Trike, I guess I would be on the phone with the dealer?
    I just gave her a Like on her post....Maybe that will pique her interest to let us know the outcome........
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Cool one hit wonder ??
    Jennifer, Welcome to Trike Talk from West Virginia.
    The people here are trying to help but they cannot do it alone.
    Jim Murphy
    Iron Butt Rider 2001
    4750+ Posts
    Mar 2015
    Texas
    I notice far too many are hit and runs. With a 2020 model my first go-to would be the dealer. There are such things as bad batteries right from the get-go. And dealerships replace those bad batteries all the time. Hope she isn't too embarrassed to let us know the outcome.
    American Legion Rider
    Probably.....Had the kill switch in the off position.......
    Once you get a starting system worked out it will become learned behavior
  1. starting my 3.8 v6 super charged trike build
    By irmagoo in forum Home Built Trikes
    Last Post: 07-13-2023, 07:14 PM
  2. Stallion Wouldn't Crank
    By Dean H in forum Stallion Trikes
    Last Post: 06-11-2015, 09:30 PM
  3. crank sensor
    By lasso in forum Harley Trike Conversions
    Last Post: 09-10-2014, 07:35 AM
  4. Power...Power, I need more power
    By SJR in forum Harley Trike Conversions
    Last Post: 08-14-2011, 10:37 AM
