Likes Likes:  7
Thanks Thanks:  4
Results 1 to 20 of 26
Thread: Roadsmith reverse issues.
    Aug 2020
    Connellsville
    Default Roadsmith reverse issues.
    Hello all, I'm New here and to triking. I recently bought a 2004 Harley Roadking with a Roadsmith trike conversion. The reverse motor tries to move but when I look underneath and push the button it looks like the gear motor that works it might be skipping teeth Inside the gear box. Has anyone had any experience with these reverse motors and how much they Cost to replace ?
  2. Roadsmith banner
  3. #2
    Quote Originally Posted by Volusiacrazy View Post
    Randall..Welcome to Trike Talk...👍👍
    If your motor is like the Tri Glides You can get a rebuilt kit 30 to about 50 dollars A new motor costs around 1500+dollars..Without labor ..
  4. #3
    Aug 2020
    Connellsville
    Where do You get such rebuild kits and motors ?
  5. #4
    There are a couple of threads right now on Trike Talk about reverse Motors do a search or you can just Google Harley Davidson reverse motors that will lead you to a lot of places were you can get parts or the whole motor....
  6. #5
    Welcome to Trike talk, look here is this your reverse set up? If it is my guess is a good electric motor shop should be able to rebuild it for you. Good Luck and check back in
    90+ Posts
    Oct 2018
    Linden, TX
    I would call Roadsmith, as they probably installed the reverse when they did the conversion. Doubt it's like the Triglide electric reverse, but I've been wrong before.
    Quote Originally Posted by irondog View Post
    You're right after looking at the video Jack posted ...It is a different motor ....
    Aug 2020
    Connellsville
    Actually my motor doesn't look like the one in the video. Mine stands up and has a 90 degree output shaft.
  10. Roadsmith banner
  11. #9
    Can you post a picture of it?
  12. #10
    Aug 2020
    Connellsville
    I plan to hopefully pull it out tomorrow and then I'll post pics. I don't know what all is involved in removing it.
  13. #11
    Aug 2020
    Connellsville
    So it turns out that the motor gearbox shaft keyway is broken out along with the belt sprocket being ruined. I called Roadsmith and they no longer using that motor or sprocket but are using a new reverse kit that cost $850.00 .
  14. #12
    Its gonna cost you, Or them $850......
  15. #13
    Aug 2020
    Connellsville
    Well me of course.
  16. Roadsmith banner
  17. #14
    Well me of course.
    I would look to see if a mechanical reverse will be a better option...Even though its a few hundred dollars more......
  18. #15
    Aug 2020
    Connellsville
    I've tried to upload photos but can't figure out how. It keeps telling me the file is to big.
  19. #16
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Randall, you need to resize the pics first, there's a limit on the size, I think it is 2 megs but don't quote me.
  20. #17
    Aug 2020
    Connellsville
Size:  38.8 KBName:  IMAG0580_1.jpg
Size:  210.8 KBName:  IMAG0578.jpg
Size:  281.7 KB Here are pics of the motor
  21. #18
    Aug 2020
    Waterloo
    Default Reverse problems.
    I have a 2008 Roadsmith Trike. The reverse went in mine too. I can hear the electric motor spin, but the gear does nothing. Mine is a Verticle mounted motor, and then it goes into a 90 degree gear box. Begining of April I contacted Roadsmith and they thing the gears inside the gear box "exploded" was their term. So I asked about a new gearbox and they said you have to buy a new motor and modify it to their new Horizontal style. Said it would be around $850.
    Screw that, for another $200 or so I will go with a MMD mechanical reverse for $1099. Of course mine has the 6 speed transmission, not the 5 that makes it a little more expensive. But this seems like a pretty rugged set up, not quite as rugged as the Baker reverse, but still much better in my mind than a electric motor. Best of all the install videos look pretty straight forward. WWW.erouwingusa.com or they are on Ebay as well. Now I just have to remove all the stock reverse stuff, but I think I can do that over the winter.
  22. #19
    Aug 2020
    Waterloo
    See my post further down. Look at the MMD mechanical reverse. A little more, but much better quality.
  23. #20
    Quote Originally Posted by codered View Post
    I have a 2008 Roadsmith Trike. The reverse went in mine too. I can hear the electric motor spin, but the gear does nothing. Mine is a Verticle mounted motor, and then it goes into a 90 degree gear box. Begining of April I contacted Roadsmith and they thing the gears inside the gear box "exploded" was their term. So I asked about a new gearbox and they said you have to buy a new motor and modify it to their new Horizontal style. Said it would be around $850. Screw that, for another $200 or so I will go with a MMD mechanical reverse for $1099. Of course mine has the 6 speed transmission, not the 5 that makes it a little more expensive. But this seems like a pretty rugged set up, not quite as rugged as the Baker reverse, but still much better in my mind than a electric motor. Best of all the install videos look pretty straight forward. WWW.erouwingusa.com or they are on Ebay as well. Now I just have to remove all the stock reverse stuff, but I think I can do that over the winter.
    Bill welcome to Trike-Talk.........Once you install the mechanical reverse you'll never regret it....Electric reverse's are a joke....Thats why they call them an ''Assist'' Reverse...
  1. Victory Reverse Vs. CSC Reverse?
    By Iowavicrider in forum Victory Trikes
    Last Post: 10-02-2020, 12:58 PM
  2. Reverse gear for a reverse trike
    By elwirth in forum General Discussion
    Last Post: 05-23-2019, 10:30 AM
  3. Rebuilt Reverse Motor having issues
    By greg3852 in forum Harley Tri Glide
    Last Post: 06-05-2017, 03:23 PM
  4. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
  5. Street Glide Trike Reverse Issues?
    By jwlz in forum Harley Tri Glide
    Last Post: 05-02-2014, 01:59 PM
