Likes Likes:  7
Thanks Thanks:  4
Page 2 of 2 FirstFirst 1 2
Results 21 to 26 of 26
Thread: Roadsmith reverse issues.
  1. #21
    Sep 2020
    Elgin
    Default Best Trike Reverse Conversion
    There are a couple of threads right now on Trike Talk about reverse Motors do a search or you can just Google Harley Davidson reverse motors that will lead you to a lot of places were you can get parts or the whole motor....
    I have a 2016 Freewheeler and have problems with my reverse, which gave out once before. After some research I have concluded that a conversion reverse gear seems to be the answer. They are expensive, but I think that's the answer. Do you have any suggestions on the best reverse gear conversion?
  2. #22
    Quote Originally Posted by Writemaster1 View Post
    Carol first let me welcome you to Trike Talk👌👌👌..
    With my 2011 Tri-Glide I put in a mototrike mechanical reverse and it’s very important to use the electrical Cut off wiring harness that comes with the kit so there’s no chance of putting it in first gear while you’re in reverse...I Probably put well over 35,000 miles on the Trike with the mechanical reverse And never had a problem..👍..
  3. #23
    Dec 2020
    gainsville
    Default reverse gear
    call me i think you have the same problem i just fixed on mine larry 352 450 3659
  4. Roadsmith banner
  5. #24
    Quote Originally Posted by ldperrine View Post
    Larry.........Welcome to Trike-Talk..........
    And it might be helpful to some others if you would just post what the fix was/is that you did on yours......
  6. #25
    Aug 2020
    Connellsville
    So I know it's been a while but I ended up finding a machine shop close to me that Made a new shaft for the gear box and made a brass bushing for the sprocket that meshes with the drive sprocket. I got it back yesterday and installing today.
  7. #26
    Aug 2020
    Connellsville
    So, I installed my reverse motor yesterday and it works like its supposed to but I can understand why it doesn't last. When you let off the button going backwards it stops immediately with no drift. That has to be hard on the plastic gear that turns it.
  1. Victory Reverse Vs. CSC Reverse?
    By Iowavicrider in forum Victory Trikes
    Last Post: 10-02-2020, 12:58 PM
  2. Reverse gear for a reverse trike
    By elwirth in forum General Discussion
    Last Post: 05-23-2019, 10:30 AM
  3. Rebuilt Reverse Motor having issues
    By greg3852 in forum Harley Tri Glide
    Last Post: 06-05-2017, 03:23 PM
  4. Reverse Or No Reverse?
    By GETRDONE in forum Harley Trike Conversions
    Last Post: 09-05-2015, 07:37 PM
  5. Street Glide Trike Reverse Issues?
    By jwlz in forum Harley Tri Glide
    Last Post: 05-02-2014, 01:59 PM
