Likes Likes:  21
Thanks Thanks:  4
Results 1 to 20 of 34
Thread: Engine went due to sumping
    100+ Posts kingfish108's Avatar
    Jan 2018
    Lee's Summit, MO, USA
    Default Engine went due to sumping
    My 2017 TG is now at the dealer with the top end removed from the engine. Lost oil pressure last week while out on a short ride. They are replacing the oil pan, oil pump, lifters, pushrods, cylinders and pistons. Pistons were pretty scarred and everything had that burnt look. They said that this is only the second stock 107 that they have seen with a sumping issue and both have been trikes. I have almost 49k on it. I looked into paying the difference to do an engine upgrade, but have decided to ride it to the end of the season and trade for a new one. Really glad my wife talked me into the extended warranty, which ends in January.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Sorry to hear of your troubles Steven. I had a friend who's '17 Ultra did the same thing. He bought a new one and hasn't had a problem (knock on wood).
    Thumbs up
    You got to love that extended warranty program. Good Luck with your repairs
    Sep 2012
    Lakeland, FL
    Apologize for the ask, but specifically what is a sumping issue?
    Jan 2018
    Oil was staying in the crank area, not going back to the oil pan and starving the upper engine. Part of the issue was the oil pump was going south
    Jan 2018
    Quote Originally Posted by ol' school View Post
    I have already started my search for a new replacement.
    Sep 2012
    Lakeland, FL
    Quote Originally Posted by kingfish108 View Post
    OK thanks, thought it had to be a pump problem somewhere. Doesn't take an engine long to go south with that problem.
    Nov 2019
    Port Saint Lucie
    Is it worthwhile putting an updated oil pump in the engine before it goes?
    Nov 2019
    Port Saint Lucie
    Is it worth while putting an updated oil pump before it sumps?
  11. #10
    Quote Originally Posted by Limited View Post
    The newest 8 lobe oil pump with seal is supposed to solve the sumping issues
    Has your trike been a victim of sumping?
  12. #11
    Nov 2019
    Port Saint Lucie
    Not yet!
  13. #12
    Nov 2019
    Port Saint Lucie
    Not yet!
  14. #13
    Sep 2016
    Springfield, Mass. USA
    Bill,
    I'm glad you asked that question!
    How does one know if they do indeed have a "sumping problem"???
  15. #14
    Sep 2016
    Do Goldwing's have "sumping" problems?????
  16. #15
    No they do not
  17. DKCustoms postbit
  18. #16
    Bill,
    The only way i can describe it is, When you are trying to accelerate the trike feels like you are towing a tractor tow sled behind you.......Or a Jake brake on a truck is turned on...My 17 did that twice, And at the time i thought it was caused by another issue' ? But i traded it in for other reasons..[Oil Migration].Before i could have the dealer check it out..
  19. #17
    Jan 2018
    My problem started last year when the oil light kept coming on when idling. I took it to the dealer and they changed the oil pressure sensor and said everything was good. The very next Saturday, I was leaving on a trip and the same issue happened again. When I took it back to the dealer, a tech came out and looked it. He checked the oil and said nothing was wrong with it. I was told that it was under warranty and to just ride it. So I did. That same day I again had low oil pressure and the engine got a little noisy. I parked it and let it cool down. When cool, it ran fine. A little later, when out on the highway, it started running like I was dragging a battleship anchor. I downshifted a couple gears, cranked the throttle way up and all the sudden something gave way and it was running fine. After that afternoon, I never saw the low pressure light again until the day it gave up the ghost.
    It is still at the dealer. They are supposed to call when the parts come in. Been torn down over two weeks and I haven't heard a word. I was looking into trading for a new one, but with some of the quality control issues I am reading about, I am going to have to think awhile. In the meantime, I am enjoying my new car and my "17 Camaro.
  20. #18
    I hope they will put the NEW 8 lobe oil pump on your engine, this is supposed to cure the sumping
  21. #19
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    Since 2017, I think they have had 4 revisions to the original 107 cu.in. M8 oil pump.
    Like Jack stated, I would insure the latest revision goes in the repair. Good Luck & keep us informed.
  22. #20
    Jan 2009
    MA,
    I have a 2020 tri I needed the seal that goes on the back of the oil pump to the crank shaft, my local dealer did a nation wide search and could not find one , had to buy a the back half of the oil pump to get the seal .He said they have bikes that have been waiting for months for parts. GOOD LUCK Today got a email from them SOUTHAMPTON H D they are closing for good , they cant survive any longer with out bikes or parts or t shirts . THE END IS NEAR
  1. Sumping update
    By Wmitz in forum Harley Tri Glide
    Last Post: 08-16-2018, 06:40 PM
  2. Sumping?
    By NC Triker in forum Harley Tri Glide
    Last Post: 07-19-2018, 03:24 PM
  3. Post those weekend traveling pics.... stuck at home due to horrendous weather.
    By missedem in forum Harley Freewheeler / Road Glide 3
    Last Post: 05-23-2015, 01:29 AM
  4. Give credit when due.
    By eastkytriker in forum Honda Trikes
    Last Post: 12-06-2013, 09:25 AM
  5. Are you riding less due to
    By Papa Zook in forum General Discussion
    Last Post: 10-09-2011, 09:45 PM
