Likes Likes:  14
Thanks Thanks:  6
Results 1 to 20 of 20
Thread: Rear Bearing Replacement
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    Default Rear Bearing Replacement
    Planning to install DK Customs rear bearing retainer plate kit. I do not have a Harley shop manual to take to the heavy truck place I am going to have press off and press on the bearings.
    Would anyone be able to post the shop manual pages or tell me what is needed to be done?
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Here you go-
    www.DKCustom.com
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Tony, Kevin has posted the info from the HD shop manual. There is no reason to be concerned that the shop you will be using does not have the HD press parts numbers. Any shop that has pressed Ford or Chrysler axle bearings will know how to do this job, they press on and off the same.
    Apr 2018
    Winnipeg
    Thank you both Kevin and Jack.
    I was out shopping for rear bearings this morning and discovered my local NAPA can't use the Harley bearing number to locate a better bearing. Their advice was to bring in an old bearing and they could either get a number off it or measure the size.
    As I don't want to pull the axles until I have all the parts, I thought I'll go buy one Harley bearing at the dealer.
    Dealer tells me there are no bearing part #83314-09 anywhere in Canada. Part is back ordered with no expected delivery date.
    So unless someone knows an SKF or Timken number , I'll have to put the project on hold for a while.
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Found this information posted by Gorilla in the thread below "The bearings I got from NAPA that have a bearing # of 6208 C3."
    https://www.triketalk.com/forum/thre...etainer-Plates
    Bob
  6. DKCustoms postbit
  7. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by OLBLU View Post
    Here is a SKF bearing that will work, You can view the actual specs of this bearing here
    https://www.skf.com/us/products/rolling-bearings/ball-bearings/deep-groove-ball-bearings/productid-6208
    Also Timken bearing here
    https://cad.timken.com/item/deep-gro...-6400-/6208-c3
  8. #7
    Apr 2018
    Winnipeg
    Thank you hardwickbv and Jack. 6208 C3 it will be.
  9. #8
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    I don't know if these guys sell premium bearings. I've ordered belts from them with no problems.
    https://usbearingsandbelts.com/
  10. #9
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    at what mileage should these bearings be replaced?
    2019 Goldwing CSC
  11. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by woody View Post
    There is no mileage replacement called out for in the owners manual
  12. #11
    Jul 2012
    Talladega,Al 35160
    so replacement is needed when you can feel play in the bearing?
    2019 Goldwing CSC
  13. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    A bit of play is the poor bearing plate design, HD will call it normal. In the long run it is not good for the bearing or the end splines on the axle. Kevin from D K Customs has designed a much improved bearing plate you can read about here http://www.dkcustomproducts.com/trik...ner-plates.htm
  14. #13
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Not necessarily. The poorly designed bearing plate accounts for most ( not all ) of the play.
    The bearing plate can be replaced with 1 from D K Customs http://www.dkcustomproducts.com/trik...ner-plates.htm
    When you change to this new plate you will be changing the bearing also. Never reuse a bearing that has been pressed on and off again, the side loading caused during pressing will fracture the bearing. You may not see it but it will come back to haunt you
  15. #14
    3750+ Posts
    Philip R's Avatar
    Feb 2017
    Noonday, Texas
    This is good info. The price of new bearings shouldn't be in the equation.
  16. #15
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    May just do this when I hit 50k...
    Miss Mysterious...
    2015 Mysterious Red Tri Glide...
    Vance&Hines head pipe w/Rhinehart slipons...Slipstream Collection...DK Lift...11" Clearview w/ recurve...HD chrome Enforcers w/Goodyear Triple Tread Assurance...just a touch of chrome & LEDs...
  17. DKCustoms postbit
  18. #16
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    The bearings I've used are National Bearings brand (Federal-Mogul), part # 208-FF
    Specs are:
    This seems to be a pretty popular bearing. Jack listed the SKF and Timken. The National Bearing is carried by some of our local auto parts stores, and I'm sure they can also get the SKF and Timken if they don't already have them in stock.
    www.DKCustom.com
  19. #17
    Apr 2018
    Winnipeg
    Just wanted to let everyone know I finally got around to getting the bearing retainer kit installed. Thank God I did because at just 5500 miles my stock retainer plates were already starting to show the " witness marks" that are on DK Customs web page. No where near as bad as Kevin's trike , but they were definitely there. It's not like we have a lot of corners here on the Prairies. Probably due to our lousy Manitoba roads. Anyway I highly recommend this upgrade to everyone.
    For those who are interested the SKF bearing part numbers are 6208-2RSJ for the rear bearings and SKF part number 62052RSJ for the front wheel bearings.
  20. #18
    100+ Posts Longbeard71's Avatar
    Nov 2018
    Talbott tn usa
    Is the original bearing a sealed or open bearing? I have looked at the part numbers some have posted and seen both type.
  21. #19
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by Longbeard71 View Post
    These are sealed bearings
  22. #20
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    We just recently published a video with the step-by-step installation process.
    www.DKCustom.com
  1. DK Custom's New Report on Trike Rear Axle Bearing Retainer Plates!
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 10-21-2020, 04:03 PM
  2. Rear Axle Bearing Retainer Plates
    Last Post: 06-22-2018, 09:45 PM
  3. Tow Pac Bearing Questions Also Light on Rear Fender?
    By seeing in forum Outrigger Style Trikes
    Last Post: 01-23-2015, 08:17 PM
  4. Rear pulley bearing gone, 2012 TG
    By nevtat in forum Harley Tri Glide
    Last Post: 06-20-2014, 08:41 PM
  5. Bad bearing in Motor Trike rear end.
    By sandrooney in forum Motor Trike
    Last Post: 07-08-2012, 06:31 PM
