Likes Likes:  9
Thanks Thanks:  1
Results 1 to 8 of 8
Thread: Check engine light again!
    40+ Posts
    Aug 2019
    Ocala FL USA
    Default Check engine light again!
    Changed handlebars on 2015 Freewheeler and had some problems with wires and codes. Finally got it all right for a while. Now here is what happens:
    1. Start up go riding.
    2. Cruise control on all is well.
    3 Turn cruise control off or stop engine.
    4. Start engine and check engine light is on, cruise control will not work.
    5. Stop engine run diagnostic have code and clear it, then cruise control works until it is turned off then repeats #4.
    Any ideas?
    Thanks to all who may respond.
    What code is displayed? The most common code would be a brake light code. That would cause the cruise to stop also
    It seems that the common thread with codes popping up and cruise not working is after a 'Handlebar'' change..?..Maybe the switches are way too delicate to be messed with, And very careful removal and re-install is needed...If not new ones ......
    40+ Posts
    Aug 2019
    Ocala FL USA
    Will check code number on my next ride and will post. Thanks
    Quote Originally Posted by USMC Old Dog View Post
    That will direct you to what system is causing your check engine light, then you can make the repairs and hopefully be good to go
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    There is a sticky at the beginning of the FW forum I posted on a "Cruise Control Diagnostic Test" that is tool free & takes 1 minute. It will test your cruise control on/set switch, clutch switch, the front & rear brake switches & rolling the throttle forward will disengage it also. Easy to understand & perform.
    Here is a link to the Sticky Michael posted, very useful tool
    https://www.triketalk.com/forum/thre...+control+check
    Oct 2017
    St. Louis, MO USA
    Thanks Jack...that's why your names green.
  1. Check engine light after changing to new bars.
    By pvt93 in forum Harley Tri Glide
    Last Post: 10-05-2019, 04:08 PM
  2. The 'Check Engine' Light Means So Much More These Days...
    By Jerry/MD in forum Harley Tri Glide
    Last Post: 04-03-2017, 12:11 PM
  3. Replies: 9
    Last Post: 03-14-2017, 03:44 PM
  4. Replies: 3
    Last Post: 03-01-2015, 12:16 AM
  5. Check engine light
    By Trapper54 in forum Harley Trike Conversions
    Last Post: 06-06-2014, 08:28 AM
