Likes Likes:  10
Thanks Thanks:  1
Results 1 to 11 of 11
Thread: Shifter pinch bolts
    300+ Posts
    Mar 2018
    Waelder, Texas
    Default Shifter pinch bolts
    Which method is better? Should the pinch bolts be installed with thread locker (hoping all stays secure) or just torqued properly so that they can be checked and retorqued regularly? Your opinions and experiences appreciated.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    I use Anti seize, it fills in the threads like loctite but re tightening does not stretch the threads like loc tite does
    300+ Posts
    Mar 2018
    Waelder, Texas
    Thanks Jack. That sure sounds better than either of my two options. That's an idea I hadn't considered,
    ...and that's why I love this forum.
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I'm putting a link to some excellent free videos on the Law Abiding Biker website discussing the shifter & Linkage issues. Very informative.
    https://www.lawabidingbiker.com/harl...fter-problems/
    Oct 2017
    St. Louis, MO USA
    Jack, I need your help understanding how this problem relates to the 2017 & up M8's & our Freewheelers.
    Just with our 2017's, what needs to be changed...is it just replacing the ends of the shift linkage with heim joints?
  6. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by MDO View Post
    That is the first thing I always do , the stock joints are JUNK. The shaft that runs thru the primary cover is another weak point to watch. Once it gets sloppy the inner shifter arm can and will raise hell with the splines. I drilled and tapped my primary and put a grease fitting in. Every oil change I grease the shaft bushings. For years all HD baggers had this fitting from the factory. The MOCO has improved the shifter arm on the tranny so no worries there.
  7. #7
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    That is a good video, tho I do not use loc tite. I use anti seize. If used correctly it will give years of service PLUS you can take it apart easily on the road with out cussing
  8. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Michael, look here for heim joints. This is who I have dealt with for years
    http://www.bungking.com/heim-joints/
  9. #9
    Oct 2017
    St. Louis, MO USA
    Thanks Jack. Our 2017's FW's are 5/16 24? I definitely want stainless steel.
  10. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Yup
  11. #11
    300+ Posts
    Mar 2018
    Waelder, Texas
    Another thing about that front inside lever, that's a smaller pinch bolt than the other three. I noticed that in the video, it was mentioned that the rear lever (at the tranny) was less problematic. The lever in the video sure doesn"t look like mine. Unless my eyes are tricking me, it looks aftermarket with a two piece design and two bolts.
    Also, I feel that the adjustment of the two shift arms need to really suit your comfort. When they are too high, you may tend to stomp on them. It takes very little effort to click a gear change. That height can be fine tuned with the linkage at the heim joints.
    I suppose that if you want to set it and forget it, use thread locker and hope for the best. I like Jack's suggestion of using anti seize. You cannot accurately check and retorque using thread locker.
  1. FIXED (sorta): Front shifter shaft lever pinch bolt snapped
    By emskee in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-02-2018, 04:59 PM
  2. Rear muffler support bolts
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 03-27-2016, 09:27 PM
  3. Pinch Bolts On EZ Steer Kit Missing
    By gr8phun in forum Honda Trikes
    Last Post: 06-22-2013, 06:54 PM
  4. Torque specs. for driver floorboard bolts?
    By azbob09 in forum Harley Trike Conversions
    Last Post: 05-22-2012, 08:35 AM
  5. loose bolts
    By sprt220 in forum General Discussion
    Last Post: 08-31-2008, 05:53 PM
