SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  2
Thanks Thanks:  2
Results 1 to 12 of 12
Thread: Battery Died Radio 1/2 volume?
    10+ Posts
    Aug 2020
    Glendale, Az USA
    Default Battery Died Radio 1/2 volume?
    I just had a new tire installed on my 1996 1500 Goldwing, when they tried to start it the battery was dead so they tried to jump it so I could at leased get it home. But it still didnt start and the wires going to the battery tender melted. I removed the melted wires and installed a new battery, and it starts great now but now my stereo is at 1/2(at best) volume. I was told it might be in the mute switch but the tuner up/down works and so does the mute switch on the handle bar, but the mute on the tank doesnt. (do they both do the same thing?)anybody ever seen anything like this? Ive tested all the grounds I could get to, no melted or damaged wires that I can see. Any recommendations are appreciated
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    What did they use/try to jump start it with....And the tender wires should of had an in line 7 amp fuse and then it should have blown before the wires melted?.....
    I hope they didn't run to much power though the amplifiers on the stereo..
    2019 Tri-Glide.......
    10+ Posts
    Aug 2020
    Glendale, Az USA
    It did blow the main fuse and a unidentified fuse 5amp under the main, and also the acc fuse. It was a well respected bike shop, I would hope they know how to jump batteries, spmeone on here mentioned a power amp fuse tucked into the relay box but all I see is relays in there
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by MadMatt View Post
    If ? All the replays are the same switch them around they might have fried one of them...
    With all those fuses blowing it sounds like they used a high amp booster/starter charger that you would use for a car..
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    I would contact Mark at D&D Discount Motorcycles in Tempe. I feel very fortunate that we have his expertise here in the Phoenix area. Explain who did what and which fuses and wires you found damaged. I'd bet he will be able to tell you exactly where the problem is. (BTW, he writes the Workbench column for the Wing World magazine). Good luck..... Jim
    2005 Premium Mustang Convertible
    2008 Honda GL1800/California Sidecar Trike SOLD
    2014 CanAm Spyder RTL SOLD
    Semper Fi
  6. #6
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Put this in another thread
    Dug this up off the net concerning this problem. Seem like it resolved the problem:
    Behind the left side cover is the fuse box, to the right of the fuse box another box with relays in it. In that box there are 2, 5 amp fuses. Check them. It's been a long time since I had a 1500 wing but IF I remember right that is the cause of your problem.
    Hope it helps
    where to find fuses and relays
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  7. #7
    10+ Posts
    Aug 2020
    Glendale, Az USA
    Default This community ROCKS1
    Ended up being behind the relay box 5amp fuse was a royal pain to get to because the conversion was in the way. but Im jammin again Thanks for everyones help.
  8. #8
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
  9. #9
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    another job well done people
  10. #10
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Matt, I am glad you got your trike running. I would strongly uge you to check your charging system after that bad Ju Ju @ the bike shop. There is no good reason I can see why your battery tender wires burned up UNLESS the shop tried to do a hot charge thru the tender plug? YIKES THat could be enuff of a jolt to burn a diode before the fuses blew
  11. #11
    400+ Posts BrokenBackJack's Avatar
    Feb 2017
    Payson, AZ USA
    Another reason why one hates to take things to a shop as you don't know if whoever works on them even has a clue what they are doing plus you are paying 100 bucks an hour!
    Johnny 7
    God, Family, Country, & Green Bay Packers
    2018 Honda Goldwing DTC Touring CSC Encore Trike Kit & 2021 Polaris General XP G2 Ride Command
  12. #12
    1500+ Posts
    Oct 2012
    Batavia Ohio
    Lots of folks on this site with so much knowledge. Great to see.
  1. Battery died
    By TG Bob in forum Harley Tri Glide
    Last Post: 10-16-2018, 04:50 PM
  2. Battery died - Part 2
    Last Post: 08-22-2018, 09:02 PM
  3. Infotainment Volume Control
    By briar in forum Harley Tri Glide
    Last Post: 08-03-2018, 03:37 PM
  4. GPS volume
    By Beorn of Ga in forum Harley Trike Conversions
    Last Post: 05-12-2013, 07:52 PM
  5. JM GL1500 CB, Volume, Mic On/Off Pass Controller
    By retdpd in forum Honda Trikes
    Last Post: 09-24-2010, 07:06 AM
