Speed Bleeders
Likes Likes:  7
Results 1 to 15 of 15
Thread: 2020 TGU steering "shift"
    Sep 2020
    Sumter
    Question 2020 TGU steering "shift"
    On my TGU when I steer to the left or right, or even just going down the road the steering will "shift a little to the left or right (depending on direction I am steering). Even when just traveling down the road it will "shift" to the left or right enough that I have to correct it back to center. It's like it is extremely touchy.
    Is this a flaw in the steering or a failure in the stabilizer bar that is attached to the forks and frame? Or something else completely?
    Tire pressure is good and tread is new-ish. No visible tire damage or rim damage. Only have put 100 miles on it since purchase. 5500 miles on it when bought from dealer as used.
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    If this is your first trike , you may still be getting used to the handling characteristics. I find that little things like where the front tire is in relation to the crown of the road will make the trike seem "nervous". Also side winds will cause you move around more than a two wheeler. You should also check the wheel and fork bearings for proper adjustment and wear.
    I had my front wheel bearings fail at 5500 miles.
    Your 2020 trike has factory warranty on it for 2 years, swing by the dealer and have them test ride it to see what they think. This should give you peace of mind.
    to Trike Talk
    Sep 2020
    Sumter
    Quote Originally Posted by OLBLU View Post
    I'll mention that to the dealer when I take it in, but I would expect that to be extremely rare for the bearings to fail at such a low mileage. I have been paying close attention to the road crown and wind effects and definitely have experienced both. I also have ridden on flat streets and no wind with the same "problem" with the front wanting to do what I call shift and you call being nervous. It's a lot like the steering on a car having play in it where you have to correct it back to center. Could this have anything to do with the sliding stabilizer that is attached to the forks and frame?
    Going out again today, so I'm getting more data. Any suggestions of what I should look out for other than what has already been said?
    Sep 2020
    Sumter
    to Trike Talk
    Definitely taking in to the dealer as soon as my other bike is out (2007 FLSTC). Peace of mind will come when it doesn't act like it wants to take off in one direction or the other.
    Thanks Jack
    Just throwing this out there:
    Trikes tend to "follow" the "hump" in the roads. The hump is the crown they engineer in the road to facilitate rain or snow (when it melts) removal. Depending on where you live, this can be significant. I never noticed it on two wheels, well, not to the extreme of a trike.
    Maybe find like a mall parking lot when it's closed that has flat asphalt or concrete and test it out. Might just be as stated by others, that you aren't used to it.
    Good Luck.
    Apr 2018
    Winnipeg
    Having the front bearings fail at 5500 miles isn't that rare. My dealer had one in at 2300 miles and I believe someone posted their bearings failed at 3700 miles.
    It's the junk Chinese bearings that Harley is using.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    Quote Originally Posted by TGDavid View Post
    What is "Good"?
    Apr 2020
    Las Vegas
    Doesn’t sound right to me. For reference I have a 19 TGU with 2300 miles. Usually ride two up and have never experienced what your describing. We just returned from a 130 mile ride through Lake Mead Park and Valley of Fire. When I’m on a long stretch of road not in traffic or tight turns I’m riding one handed. The trike is rock solid, no twitch. 70 MPH on the freeway one hand when other vehicles are not around me, no shift. I run 36 in the front and 22 in the rear. I would have it checked.
  11. #10
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    David,
    I'd like to know what air pressure you are running in your rear tires.
    I'd suggest you drop it to 22 lbs and see how that affects the issue.
  12. #11
    Quote Originally Posted by B SMITH View Post
    Brian........Welcome to Trike Talk...................
  13. #12
    Jan 2009
    MA,
    I had the same thing from the day I bought, on the highway it was like there was 40 mile an hour wind gust , It got worst the more miles on it ,mine was scarry, I change the front tire to a Avon 91 it was like a new trike . maybe thats what you have ??
  14. #13
    450+ Posts TonkaDriver's Avatar
    Feb 2018
    Bagdad, AZ, USA
    Thanks Jack
    I'm with Jack. You are under warranty so have the dealer check it out. Could be a loose Panhard bar. With the trike sitting, shake it sideways and listen for a clicking. If it clicks, something may be loose in the rear suspension.
    Kurt
  15. #14
    Dec 2013
    Clarion PA USA
    The wandering possibly could be just needing aligned sometimes it just doesn't get it from the factory. After I did ours it was a different machine. Just sayin Fred
  16. #15
    60+ Posts Rally's Avatar
    Nov 2010
    Elkin, North Carolina, USA
    There is a lot of good info in the replies thus far....I also found that by lowering the pressure in my rear shocks I relieved some downward pressure on the front tire creating a balance front to rear and solved a problem that I had with curves and tire skipping giving me better steering control.
    2016 H-D Tri Glide
    TOI #00485
  17. DKCustoms postbit
  1. 2020 Triglide "Duckie" Tahitian Teal
    By gfaltersack in forum Harley Tri Glide
    Last Post: 04-27-2020, 07:47 AM
  2. Freewheeler Steering vs Tri Glide Steering
    By POPSHD in forum Harley Tri Glide
    Last Post: 01-08-2020, 09:45 AM
  3. Replies: 10
    Last Post: 06-20-2016, 05:23 PM
  4. When it won't shift down
    By Reader1 in forum General Discussion
    Last Post: 08-28-2011, 08:19 PM
