Thanks Thanks:  8
Results 1 to 9 of 9
Thread: Reflex defensive rider system - Tri glide
    30+ Posts dpete's Avatar
    Sep 2020
    Sachse, TX, USA
    Default Reflex defensive rider system - Tri glide
    Hi,
    I am new to the forum and looking at trikes. HD vs GW, of course.
    Coming from 2-wheel riding, I want to get the best safety I can.
    I know the GW has ABS, and the new triglides have the reflex system with traction control and ABS.
    is there any forum here that compares/contrasts these two bikes in terms of safety and wheel control?
    what year did the triglide offer this technology?
    dpete
    300+ Posts
    Mar 2018
    Waelder, Texas
    Sorry, I can’t help, but I’m sure someone will soon. Welcome to TrikeTalk!
    2500+ Posts GARYD's Avatar
    GLEN ELLYN, IL. USA
    Go to https://www.triketalk.com/forum/forum.php - they have everything related to trikes - Harley - GW - Victory - Yamaha - kits - conversions - EVERYTHING
    Don't forget Harley is a FACTORY model and GW is a kit. Check out warranty services and service while you are on the road.
    I personally would not even consider anything but a factory model. If you don't want solid rear axle - forget Harley unless you get a conversion.
    Good luck
    IBA#61162
    PATRIOT GUARD
    USMC
    350+ Posts
    Aug 2020
    Monaca, Pa, USA
    Quote Originally Posted by dpete View Post
    Hi,
    dpete
    I just came from 2 wheels as well. I considered conversion trikes. Of those prob Honda tops the list and ride. However , like mentioned already Harley is the only factory trike. I have had mine 1 monthand put on 1,600 miles. We love it. Also appealing to me was a more narrow rear wheelbase when compared to most conversions. The 2020 with the 114 has plenty of power. Harley Tri Glide also a good bit cheaper than the conventions i looked at. Hope this helps.
    Hi Danny and to Trike Talk
    If you have not read this info check out this link, it may answer some of your questions.
    https://www.harley-davidson.com/us/e...r-systems.html
    Just Killing Time...
    paws's Avatar
    Kerrville, TX U.S.A
    Danny..another factory 3-wheeler to consider is the Spyder. The 2020 RT Limited is really nice and comfortable... check it out!
    p.s.. if you test drive one be aware that they have a very quick response on the throttle. Its fun!
    Sep 2020
    Sachse, TX, USA
    Thanks for all of the replies. I will probably go for a factory trike.
    HD or Can am. They are so different.
    I want to study more on the dynamics of two rear vs two front tires. I do like the reflex ABS system on the HD, but I am not sure what year it was introduced. I cannot afford a new HD. I wish I could.
    200+ Posts Wmitz's Avatar
    Jun 2018
    Crossville, TN, USA
    The only downside for rdrs is there is no hill brake for trikes, not that it is needed, but it is not offered. Welcome to three 🍻
    Reflex brake systems introduced on the 2019 model trikes
  1. Tri Glide Reverse System Diagnostic Tips
    By MDO in forum Harley Tri Glide
    Last Post: 01-20-2021, 05:18 PM
  2. Harleys New Reflex Defensive Rider Systems
    By Jack Klarich in forum General Harley Chat
    Last Post: 09-06-2019, 08:29 PM
  3. Tri-Glide "trunk warning system"
    By Texan in forum General Discussion
    Last Post: 05-12-2017, 10:55 AM
  4. Trike kit for Honda Reflex 250
    By Susanner in forum Honda Trikes
    Last Post: 09-19-2015, 04:56 PM
