Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  10
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: Rocker Lockers Install vs. Cylinder Position
  1. #21
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by keikat2 View Post
    Jack, From reading about 4-stroke engines and trying to educate myself, there are four stroke positions of the cylinder. The first is the intake downward stroke with the intake valve open and the exhaust valve closed bringing in air & fuel to the cylinder. The second is the compression upward stroke where both intake/exhaust valves are fully closed at TDC burning the air/fuel created by the spark plug's spark. The third is the power downward stroke still with the intake valve closed and the exhaust valve beginning to open as the cylinder starts to reach bottom. The fourth is the exhaust upward stroke with the intake valve beginning to open and the exhaust valve fully open to expel the burnt air/gases. Then the process starts all over again.
    Now, if my understanding is correct, the only time both the intake and exhaust valves are fully closed is during the compression stoke at TDC. In turn, at this time, it would be the only time that both cylinders' pushrods would be at the same height with no tension or pressure on the selected cylinder's rocker arms and springs as viewed inside the selected cylinder's support plate you are wanting to remove and install the rocker lockers. Please let me know if this sounds correct?
    Also, in addition to the new Harley Breather Assembly kits and O-rings, I will be installing new rocker cover gaskets, as well, just in case one of the old rocker cover gaskets gets "dinged" or scrapped. From what I have read, the same rocker cover gasket works for both front and rear rocker covers. However, the gasket will have "front" or "rear" cylinder imprinted on the top side of the gasket to indicate its proper placement.
    Thank you,
    Allen S.
    Yes your statements and understandings are correct. The main thing to understand about HD engines is they share a common crank shaft connection to the connecting rods. This is the direct relationship to the piston travel in both cylinders. It is pretty confusing until you see it all in motion
  2. #22
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Jack, Thank you for sending me the animation workings of the Harley engine. Observing the animation, it appears a cylinder's push rods, rocker arms, springs, and valves are all in a non-tension resting position beginning at the bottom of the cylinder's intake stroke moving upward to the compression stroke all the way down to the bottom of the power stroke. In turn, if I am correct, it appears the selected cylinder's rocker support plate could be removed at any point during this movement of the cylinder. Am I correct?
    Thank you,
    Allen S.
  3. #23
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Thank you,
    Allen S.
    Yes, the intake and exhaust should both be fully closed as the piston for that cylinder is ready to move up the compression stroke
  4. #24
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Have a look here you can see the lift area of the cam and the base where the valve closes
  1. DK Custom Introduces Rocker Lockers ~ Get Rid of the Annoying Top End Ticking
    By DK Custom Products in forum DK Custom Products
    Last Post: 05-23-2023, 11:11 AM
  2. which clutch slave cylinder kit to install?
    By El Lobo in forum Harley Tri Glide
    Last Post: 02-09-2020, 03:02 PM
  3. Rocker Lockers
    By jc1300 in forum Harley Tri Glide
    Last Post: 01-15-2020, 11:53 PM
  4. ***DK Custom Products Save 10% on Rocker Lockers -Limited Time***
    Last Post: 01-18-2016, 08:17 PM
  5. Howdy from the old Rocker...
    By rocker bri in forum New Member Introductions
    Last Post: 11-27-2009, 04:47 AM
